Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: recent job
    Apr 2006
    TAXACHUSSETTS
    1,515
    Default recent job
    Few pics of railing just did.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    May 2012
    215
    Default recent job
    Hmm is that just 1 1/2? Pipes cut at random lengths and shoved into wooden posts then painted with a rattle can?
    Apr 2011
    367
    Default Um...NO
    Quote Originally Posted by drpipe View Post
    If you looked closer you would notice brackets ON the posts...but I'm sure his welds are not near as good as yours 24k...shame your eyes aren't near as good though.
    Just For Home Projects.
    Apr 2006
    TAXACHUSSETTS
    1,515
    The brackets are anchored with lag screws into the post.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Cave Creek Az
    1,097
    Oh, you used lags. Next time try a birch dowel at about 75 amps, to stick weld them on. If you get the foil covered dowels from the craft store you can do aluminum to wood as well
    Looks good.
    Edmonton,Alberta.
    632
    Quote Originally Posted by walker View Post
    Looks good.
    Yes but,what keeps the wood from burning?
    Apr 2006
    TAXACHUSSETTS
    1,515
    Looks good.
    I,ll stick with lag screws thanks.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    May 2012
    215
    Default recent job
    Lmfao ........ Did ya stove pipe it
    Cave Creek Az
    1,097
    Quote Originally Posted by Cornerstone View Post
    You just keep the amps low, and like some guys do with 6010, you can dunk 'em in water, as they need a little moisture to lay a good bead.
    Mar 2011
    st-eustache qc.canada
    262
    wood needs oxygen to burn, keep your shopvac near by and suck-it
    edit: sorry for hyjacking the subject, the work done is a good job and i'm sure the customer is happy about it.
    note: english not being my first language people here made me work harder to keep up with the birch dowell thing...lmao too ;o)
