    Jun 2006
    Default Miller CP 200 3 phase to single phase help??
    Hello everyone,
    I am new to this site and need some help. I bought a used Miller CP 200 welder, Serial # JE795169, has Millermatic S-52e wire feed set up to run 3 phase. I do not have 3 phase in my pole barn, I DO have 220 hook up. I was checking on transformer and was expensive . I have heard that I can rewire this 3 phase into single phase to run on my standard 220 set up.. Can anyone help with this, or send me to site that would explain how to rewire ?? I do not have a manual for this machine, Inside of side cover has electrical diagrams ( 2 ) but I do not know how to go by these to rewire unit.. Any help would be appreciate......Thanks - Bill W.
    Sep 2002
    Clark County, NV
    2,696
    You cannot rewire this unit to single-phase. I own one also. It's in storage until I have 3-phase power again.
    It is not recommended to run this unit with a phase converter either, though I have heard reports of some doing it.
    Jun 2006
    Default 3 phase power
    Hello, Thank you for your input. I just had 100 amp power hooked up to my pole barn, What what I have heard, if I want 3 phase power I would have to have another power line run to my barn ??? from the power Co. is that correct ?? thanks again, Bill
    Sep 2002
    Clark County, NV
    2,696
    Yes, it will require 3 wires (plus the neutral), at least one of which will have to come all the way from the nearest pole that has 3-phase available. It will also require that they replace your transformer with a 3-phase. Everything involved is usually expensive, and sometimes they just say no.
    Sep 2011
    8
    Post
    I know this thread is really old, but thought I'd toss in a little update...
    Quote Originally Posted by MAC702 View Post
    It CAN be run, with full output and excellent results, off of single-phase. It takes a LITTLE MORE than rewiring, but not a difficult job. Here's how:
    http://www.practicalmachinist.com/vb...-phase-199832/
    Jul 2010
    Four Flags city
    298
    Hey Dave good to see you on the clean side of town.
