Results 1 to 10 of 16
    May 2005
    10
    Default Trailer Receiver 4 Winch, Will she go? Or will she bow?
    All pull goes straight out the rear of the trailer thru the alum fairlead.
    9000# winch, Northerntool $349.00 free ship special!
    Any pro fab guiys see any issues?
    I will weld it up w/ a Miller "VINTAGE" machine.
    All holes you see are for plug welds.
    I mean drastic changes would blow, will it work OK? OR BEND? Ugghhh
    Is it OK but next time I might do "________" ?
    THANK YOU in advance!
    (see two posts for all pics)
    May 2005
    10
    Default More pics...
    More pics...
    May 2005
    10
    Hmmm, Now that I look at these pics I wonder if I should X member behind it
    under the trailer? I am going to go picture that....
    May 2005
    10
    OK so there is a piece of 3' x 1.5" x .125" channel directly behind the
    2" x 8" x .250" channel... I would like NOT to X brace, for below is storage
    and the bracing itself will cut down on storage height...oh well, if I have to I will.
    Hmm, to X brace or not to X brace, that is the question....
    4,364
    I might reach in behind and put a couple welds on the 4 inch to the 8 inch on the bottom,,, in the pic with your hand, you wouldn't even need the gussets, this is plenty strong, will stall the winch. It wount hurt but I would have skipped the plug welds. As for changes to doing it again woul have probably just welded the tube on. Possibly as little as 3 rods.
    May 2005
    10
    Thank you for the reply. You idea is valid as well and it certainly can't hurt.
    I believe I will make it so...
    I felt what I had pictured was sufficent. On purpose I left 2 more vertical
    gussetts I had planned on using out of the first set of pics. I got some good
    feedback on another forum and went ahead and welded it all up. Although
    my welding skills are lacking due to self teaching and utube I do know what
    penetration is I am am sure it is "welded together". Here it is after I hit it
    lightly w/ a portable glass bead blaster;
    Frankly I was very surprised I only got one reply in this forum. Granted I am
    not here a lot myself. I would suggest that "restrictions" one runs into here
    play into why attendenance is low. Why only 4 pictures in any one thread?
    It does not make people "happy" and why? I mean personally I always reference
    a URL w/o saving the picture locally. If people do that why the restrictions? Lame, IMO.
    I received DOZENS of replys in a tractor forum I am in...
    OMG! I just found out a silly SMILIE counts as a PICTURE...THAT STUFF TICKS
    PEOPLE OFF MR MODERATOR!
    May 2012
    5
    Default Good work
    I dont think that reciever is going anywhere. NICELY DONE!
    Feb 2008
    Middle of Nowhere Wyoming
    3
    Default Looks great!
    Looks stout, no sharp corners, I'm going to copy your idea. Thanks
    Feb 2008
    3
    Default Question about the stars
    Did you use a iron worker/punch press to make the stars in the gussets?
    May 2005
    10
    The stars and all parts were cut by water jet after I drew the parts in CAD.
