Results 1 to 7 of 7
    Apr 2008
    BC, Canada
    45
    Default Quick warning for visitors to your shop
    I wanted to be able to prevent my wife from getting welding flashes when she comes into the garage (My shop) without knocking. I couldn't train her to knock so I made this.
    First I put a "Man's" bathroom sign.
    Then i took some plexiglass rod that I had from something else.
    (I imagine a clear stick for adjusting window blinds would work well too.)
    I cut the rod .5" longer than the thickness of my door and rounded over one end.
    I tried to heat it to make the ends clear but it did not work (still working on that solution).
    The I drilled 2 holes where the eyes would be on the "Man" sign and jammed the rod in with the flush side going into the house and the .5" extra going into the shop.
    If the lights are on in your shop the eyes will glow. if you are grinding near the door the eyes will glow orange (or whatever color the sparks are) and if you are welding and the light from the arc is getting on the door the eyes will glow very bright.
    Hopefully the pictures fill in the spaces in my description.
    Any ideas or comments are welcome.
    Jul 2008
    Waupun, WI.
    31
    Nice idea!
    At home:
    Dynasty 200 DX
    Millermatic 211 Auto-set
    Spoolmate 100
    At work:
    2-Syncrowave 250
    2-maxstar 150
    millermatic 250X
    Dynasty 200 DX
    Oct 2007
    Arizona
    119
    To make the ends of the plastic rod "clear," polish them with some very fine polishing compound.
    Dec 2009
    Melbourne, Australia
    87
    Quote Originally Posted by GilaSlim View Post
    +1
    Headlight restore if you got it.
    Kemppi Pro Evolution 4200
    Kemppi 530 wire feed with MXE panel
    Kemppi ProCool ( coming soon)
    Cigweld TransMig 210se
    Cigweld TransTig 200 AC/DC
    Hypertherm PowerMax45
    CutSkill O/A setup
    Speedglas 9000x adflow
    Speedglas 9100xx
    Aug 2006
    Raymore Missouri
    1,920
    Try dipping them in acetone. Thats how they clear screwdriver handles after machining in factories
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Dec 2011
    Ray City GA
    14
    That's cool!
    Feb 2007
    asheville n.c.
    618
    inside latch works for me
