Results 1 to 7 of 7
    Jun 2012
    3
    Default diversion 180 clamp on meter test
    Has anyone done an amp metrr test on this machine??? My meter only does ac current so i set the machine at 180A and was getting a reading between 127 and 140a. This machine is about a month old. I havent done a dc current test. Has anyone got a similar reading??? Is my machine broke???
    Deltaville, VA
    2,239
    Machine's probably fine but there's likely a screw loose with the operator.
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
    Jun 2012
    3
    So am i not suppost to get the full 180A reading on the meter???
    Aug 2009
    New York
    17
    That's a helpful answer, even for those of us that didn't ask it. It's quite unfortunate that Miller owners cannot come here for answers instead of abuse, but that's the reputation this forum carries... Too bad.
    Nov 2010
    265
    Quote Originally Posted by eric View Post
    You should try several different locations along the work lead and even the ground lead and compare your measurements. Location, location, location can make an incredible difference in your measurements.
    8,018
    Clamp meter is NEVER going to read correct if the unit has high frequency, and may damage it. Even if the HF was turned off, the unit may never get to 180 amps unless the unit was loaded to the max. Thats with the correct and largest tungsten and pretty much dead shorted. In other words if your machine is welding fine, it's working fine.
    I don't load tig machines with a load bank in tig, only in the stick setting and only to its data plate specification.
    Jun 2012
    3
    Thanks alot cruizer.. When i have to do a calibration on our maxstar units at work which are dc only machines i get an almost exact reading (on a dc test) so i yhought it would be the same for ac... Anyways thanks again..very helpful
Tags for this Thread
