Thread: Crimper Repair
    May 2008
    Troy, MI
    361
    Default Crimper Repair
    My latest job was to fix a crimper for fittings for hydraulic hoses, with a bend stub shaft on the actuation lever as shown in picture 1. The way the crimper works is you manually push on the lever, which actuates an eccentric which crimps the fitting. The stub shaft kept bending, because the stub shaft was weakened by two flats on the shaft and a hole located in the high stress area. The original stub shaft is shown in picture 2. My buddy asked me to weld it up. Instead of welding it up I decided cut off the old stub shaft from the tubular handle and replace it with new one, which I turned on my lathe. The new stub shaft that I made and the original tubular shaft are shown ready for welding in picture 3. A close up of my weld is shown in picture 4 and the crimper with the new shaft is shown in picture 5. The new shaft has considerably more cross sectional area so I am hoping that it will hold up. When in use the crimper is clamped in a vise so it does see a huge bending moment.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Jan 2012
    Metro Detroit, MI
    185
    What is this made of I have never seen a hydraulic crimper like this
    Never Satisfied
    Millermatic 211
    Maxstar 150STL
    Metabos
    Kennedy Maintenance Pro Full
    Makita Cordless 18v Li-Ion
    Stihl TS 420
    Timfrank88@live.com
    May 2008
    Troy, MI
    361
    Quote Originally Posted by Rezeppa View Post
    Attached is a picture of the inside of the crimper.
    You can see four dies which look like they are made of tool steel.
    The dies are mounded on slider blocks, which slide in slots in the base which looks like it is made of cast iron.
    The slider blocks are attached to linkages.
    Both the slider blocks and the linkages are likely made of alloy steel.
    The head that rotates looks like it is made of forged steel.
    To me it looks like a serious well made tool.
    Don
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Mar 2011
    st-eustache qc.canada
    241
    Default good job
    to me also it looks seriously well made and your repair improved-it.
    i have seen some simmilar attachment on pipe and rod threading machines used as
    vise to hold the pipe or rod to be threaded, very powerfull holding even if you
    tought you did not tightened it enough, it never slipped a bit.
