The following are several pics of some welding projects I recently completed. I am largely self taught with the most time on MIG welding. TIG and Stick have only been recently.
These were all done with metal I scrounged or had on hand.
This is a welding table.......was all MIG welded except for several small welds that I TIG welded after I ran out of gas for the MIG.
The last is a vice stand I made for use outside. Two of my three welding tables have a receiver style for the vice and I built this to take advantage of this. All MIG welded.
Results 1 to 5 of 5
07-18-2012, 07:36 PM #1
Member
- May 2010
- 56
Some welding projects....looking for opinions part 2 !!!
07-19-2012, 06:14 AM #2
The table looks fine but the vice stand I have a proplem with. If the vice is extended with weight in it, it will be subject to tipping. Also I would have put the vice bar in line with one of the legs which I think should be longer.
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
07-19-2012, 02:21 PM #3
Member
- May 2010
- 56
07-20-2012, 07:22 AM #4
- Sep 2008
- Dalton, GA
- 108
Hi, RAH.
I looked at both posts.
I think you did a good job welding/painting, etc.
Everybody finishes a project and thinks "now, how could I improve that?", so there will always be opinions on how to do better.
Both of these look like fun projects and I'm sure you learned from each.
Keep posting and keep welding!Burt
_______________________
Miller 211AS
Miller 375
Miller Thunderbolt XL
http://www.10FtDrillBit.com
07-20-2012, 07:34 AM #5
Good job, you just joined the club of the guys that made something to be improved, in fact this happens to me on most of my projects...
the best prospects always show-up after the wedding
