Results 1 to 3 of 3
    Default Stainless to Aluminum TIG
    Hi, I'm welding an insert into an aluminum tube, but I have an opening close to the weld that I need to stay open. Will inserting a stainless steel strip into the opening prevent it from closing?
    Medina, Wisconsin
    103
    Quote Originally Posted by Weldingchick01 View Post
    I would try some copper. The melting point of copper is much higher than of alum.
    Kirk Kopitzke
    Service Technician
    Miller Electric Mfg. Co.
    Aug 2004
    Milan Michigan
    1,423
    A piece of carbon air arc rod works good on steel to keep the weld out of a threaded hole, However because your welding aluminum I think copper would work better for your situation.
