Just bought used Lincoln precision Tig 185 with water cooler, this is my first attempt at welding 1/4" aluminum after endless hours of research on the internet mostly here and at weldingtipsandtricks.com. Im using a water cooled torch, #8 cup, 3/32 2% thoriated tungsten, gas lens, 3/32 4043 filler rod, 18 cfm argon gas. I have penetration turned all the way up, pulse off and post flow at about 20 and the amps are at max 185. I used stainless steel brush to clean joints,then sprayed with aluminum cleaner I also beveled all joints that I was able to. Its 1/4" C channel on 3/16 plate. I mig and Tig at work but only mild steel and stainless. This is my first Welder for my personal use, I really want to get good at aluminum. The inside corners are very hard to get to. I would really appreciate any suggestions
Results 1 to 10 of 23
06-07-2012, 09:05 PM #1
Tig welding 1/4" aluminum 1st attempt
06-07-2012, 09:09 PM #2
Get more amps or preheat
06-07-2012, 09:20 PM #3
cant upload pics?
Keep getting errors when trying to upload pics
06-07-2012, 09:20 PM #4
Preheat
How do I preheat after cleaning?
06-07-2012, 09:29 PM #5
Pics
Uploaded pics to profile public folder but cant upload to thread
06-07-2012, 09:45 PM #6
1/4" channel to 3/16" plate is going to take everything that 185 has to offer.
Material must be real CLEAN and more than a wire brush is likely needed - especially on less than perfect finish material.
What kind of "aluminum cleaner" are you using?
You could probably turn the cfh down a bit using a gas lens too.
Preheating can be done with a small propane torch.
Looks like you may have dipped the tungsten a time or two. Must regrind if dipped to have proper arc control.MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
06-08-2012, 07:40 AM #7
I would switch to 1/8" tungsten. Won't gain you heat but will give you slightly longer life. Machine maxed, pedal floored, pre-heated with oxy/acet or propane, then weld. You might have to stop for more pre-heat & duty cycle. Did I say duty cycle? Yes you will hit it, watch your welding time carefully. Corners are tuff cause they soak up a lot of heat by virtue of more mass.
I used a lincoln tig 175 for years & have done this. O/k for occasion but if your doing it a lot look for a bigger machine or mig.MM250
RCCS-14
06-08-2012, 07:41 AM #8
MM250
RCCS-14
06-08-2012, 09:14 AM #9
Chem Etch the joints, preheat, and get yourself a bottle of Argon75%/Helium25%.
Backfeed into the corners if you have the talent.
Back off your balance as far as possible until your tungsten balls back too much. You are not allowing the puddle to form on the surface with your balance at full penetration. The puddle will just not glaze if you are at full pen on the balance knob.
Good luck.Nothing welded, Nothing gained
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
06-08-2012, 06:56 PM #10
- Feb 2009
- 151
