Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Jun 2012
    11
    Default Tig welding 1/4" aluminum 1st attempt
    Just bought used Lincoln precision Tig 185 with water cooler, this is my first attempt at welding 1/4" aluminum after endless hours of research on the internet mostly here and at weldingtipsandtricks.com. Im using a water cooled torch, #8 cup, 3/32 2% thoriated tungsten, gas lens, 3/32 4043 filler rod, 18 cfm argon gas. I have penetration turned all the way up, pulse off and post flow at about 20 and the amps are at max 185. I used stainless steel brush to clean joints,then sprayed with aluminum cleaner I also beveled all joints that I was able to. Its 1/4" C channel on 3/16 plate. I mig and Tig at work but only mild steel and stainless. This is my first Welder for my personal use, I really want to get good at aluminum. The inside corners are very hard to get to. I would really appreciate any suggestions
    561
    Get more amps or preheat
    Jun 2012
    11
    Default cant upload pics?
    Keep getting errors when trying to upload pics
    Jun 2012
    11
    Default Preheat
    How do I preheat after cleaning?
    Jun 2012
    11
    Default Pics
    Uploaded pics to profile public folder but cant upload to thread
    Aug 2008
    Orange, TX
    1,215
    1/4" channel to 3/16" plate is going to take everything that 185 has to offer.
    Material must be real CLEAN and more than a wire brush is likely needed - especially on less than perfect finish material.
    What kind of "aluminum cleaner" are you using?
    You could probably turn the cfh down a bit using a gas lens too.
    Preheating can be done with a small propane torch.
    Looks like you may have dipped the tungsten a time or two. Must regrind if dipped to have proper arc control.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    1,880
    I would switch to 1/8" tungsten. Won't gain you heat but will give you slightly longer life. Machine maxed, pedal floored, pre-heated with oxy/acet or propane, then weld. You might have to stop for more pre-heat & duty cycle. Did I say duty cycle? Yes you will hit it, watch your welding time carefully. Corners are tuff cause they soak up a lot of heat by virtue of more mass.
    I used a lincoln tig 175 for years & have done this. O/k for occasion but if your doing it a lot look for a bigger machine or mig.
    1,880
    Quote Originally Posted by Goose14 View Post
    Stainless wire brush, pre-heat, quick brush again then weld.
    Aug 2010
    1,168
    Chem Etch the joints, preheat, and get yourself a bottle of Argon75%/Helium25%.
    Backfeed into the corners if you have the talent.
    Back off your balance as far as possible until your tungsten balls back too much. You are not allowing the puddle to form on the surface with your balance at full penetration. The puddle will just not glaze if you are at full pen on the balance knob.
    Good luck.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    151
    Lightbulb
    Good luck.
    Confuse the newb some more.Etching, buying helium mix... come on the guy's machine is underweight for doing it anyways.He don't have enough amps welding on a heatsink.
    ''True genius,in many fields of human endeaver,is often revealed in elegant simplicity"
Tags for this Thread
