ive burnt boxes of 7018. guy showed me how he welds with 6010. its kinda like he dabbed some weld and brought the rod out so weld would freeze a second and take the heat out and come back in. i guess a whipping motion? any tips from you peoploe that burn it would be appreciated. i got 7 or 8 lbs to practice this weekend
Results 1 to 10 of 34
Thread: 6010
06-02-2012, 11:34 AM #1
- Feb 2007
- asheville n.c.
- 595
6010
06-02-2012, 12:47 PM #2
I ran enough of that last summer to know to throw the rest away. Just my thoughts...Bob
06-02-2012, 05:28 PM #3
- Oct 2006
- Illinois
- 458
6010 rod has its place .I would not throw it away ! It cannot be beat for rusted , dirty, or painted metal.
Yes, it is a fast freeze rod. Great for filling a gap. Get puddle started, sometimes
it may take a bit to get gap filled. Once you have it started move rod away from
puddle to allow it to cool. The moving distance depends on how hot your heat is and how soon the puddle freezes. It is a whipping motion. Sometimes on a wide gap, as you draw rod away,follow the side of the joint to try to add metal from rod before you get to that point. It's kind of hard to explain.
This rod is great for welding on galvanized metal without cleaning.
06-02-2012, 06:07 PM #4
6010
Hey sky walker 6010 is a lifesaver of a rod . I know ya said you do not run much stick you play with those wire guns all day. I normally burn stick or tig I don't play with wire anyway when I fabricate anything or build any structure I tack everything with 6010 and usually run the first pass with 6010 it is such a forgiving easy rod to burn its only drawback is its dirty and smoky . Yes you can run up or down and start to fill a gap or even a 3/8 th hole just whip it back in forth until your gap is filled you can build each side up until the gap is filled even on jobs where they want 7018 or 8018 welded all the way out I carry a handle full of 6010 for a when you have a bad fit up . I also will use it on pipe jobs that require 8010 bead 8018 fill cap I still tack with 6010 unless you heat 8010 up with a torch it won't move withought breaking 8010 sucks but 6010 moves where you want it . It truly is a lifesaver I've only welded up here in ak it amazes Me every summer when guys come up from down south 9 times out of ten they can't run 6010 beads or haven't done it since welding school . I guarantee you will like the **** out of this rod fit something up with a big gap and run a downhill bead just step down if you start to burn thru when the puddle cools move right back up and then continue down
06-02-2012, 06:09 PM #5
- Feb 2009
- Lodi, CA
- 1,126
06-02-2012, 06:35 PM #6
06-02-2012, 07:48 PM #7
Yes i am an idiot when it comes to 6010, 6011, 6013 as i have not used any of it much. In my 34 years of welding in many shops it was all 7018 or SS or tool and die rod. The refinery i worked at outlawed anything but 7018 or special alloy rods for high chrome pipe. The foundry was all 7018. Every stick welding test i have done was 7018. My last job on the river boats we tested with 7018 and gas flux core. There isn't a stick of anything but 7018 in the shop i am at now and i don't use anything but 7018 in my shop. So yes i am an idiot on 6010 and it won't be the first rod i grab...Bob
06-02-2012, 07:51 PM #8
- Sep 2005
- 4,246
Farmer weld on a crack.
06-02-2012, 07:57 PM #9
6010
Bob is right ..... The welding inspections industry hates 6010 ....... Which is so funny to me because the oldest parts of the plants refineries and platforms were built with it until sometime in the 80's the good welders butterfly laced capped there pipe with it. Long live 6010!!!! It is a welders best friend
06-02-2012, 08:42 PM #10
- Feb 2007
- asheville n.c.
- 595
Fired up the 302 tb and burnt about ten rods of it on a cut off beam i had. I see its a fast freeze rod deep penetration and you better move it or you will melt ylur base metal out. I just about have it looking like a stack of nickels. Im gonna burn all of it tomorrow.
