Results 1 to 10 of 12
    407
    Default cleaning corroded aluminum
    guys
    how do you clean corroded aluminum before tig welding ?
    welding 6061 with 4043 filler.
    im thinking on using either a sanding flap disc on a 4 1/2" angle grinder or a scotch brite wheel on an air grinder...
    just curious as to what you guys use..
    is denatured alcohol a good solvent to wipe it down with ?
    thanks
    Syncrowave® 200
    Lincoln AC/DC 225/125
    561
    I use acetone for a cleaning solvent.
    Kevin
    Lake of the Ozarks MO
    3,594
    It depends on what corroded it and how bad.
    Without pics or at least a detailed desciption it would be wrong to give you an answer IMO
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    4,496
    4 inch wire wheel and rip it.
    Aug 2010
    1,181
    I have been using muriatic(pool)acid.
    But I have just heard EasyOff oven cleaner and Draino work too. Will be trying them both.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Nov 2003
    3,728
    I would use phosphoric acid.... it is the most accepted method of cleaning off corrosion and etching the surface in fields like aircraft refinishing (some industrial cleaners also add hydroflouric acid... but it is highly toxic and dangerous.. so I would avoid them)
    Phosphoric acid is ALSO commonly used as grout cleaner and can be found in home depot type stores in the ceramic tile section......
    phosphoric will remove corrosion without damaging the metal....
    here is a data sheet for one phos acid based cleaner..
    http://www.chemical-supermarket.com/...20Bulletin.pdf
    here is a link to amazon.. not cheap but a gal will last quite a while...
    http://www.amazon.com/gp/product/B00...DST6O3EPD4O5S3
    BTW this method will also clean the dark surface oxidation off of aluminum boats.... leaving a clean matte white aluminum surface...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Mar 2011
    La
    323
    I agree with H80N, I use Alumabright Cleaner ( an acid wash). Works great, removes all corrosion. Here is the link. http://www.envirotechcoating.com/Aluma-Brite/
    Dynasty 200 DX
    Millermatic 350P
    30A Spoolgun
    Lincoln Pro Mig 140
    Hypertherm Powermax 30
    14" Rage Evolution dry saw
    40 ton press brake
    Evenheat Heat treat oven
    1x42 / 4x48 belt grinder
    Nov 2003
    3,728
    Quote Originally Posted by ja baudin View Post
    Thanks for that link.... the instructions tab on that site explains it much better than I ever could
    http://www.envirotechcoating.com/Alu...structions.pdf
    My Blue Stuff:
    407
    thanks for all the helpful tips guys..
    sorry i left out how it got corroded. its 5/8" x 4" flat stock that sat out in the rain and heat for about 3-4 weeks. got corroded on the areas in between each piece.... some areas are very grey and some almost black areas..
    thanks again guys
    Syncrowave® 200
    4,496
    I take stainless toothbrush, brush up the joint and weld it. If its got oil on it take a little shot of brakekleen and rinse it off, air it all out before welding on it. Even stuff exposed to weather usually simply toothbrush up and get on with my life, not every joint needs to be for the space shuttle. Most of the time really don't even use the foot pedal or have it set to floor it.
