Results 1 to 10 of 14
    May 2012
    7
    Default Trailblazer 250G restoration project... no power
    Hello everyone. I picked up a Miller Trailblazer 250G as a fixer upper.
    Serial # JG138621 Hours = 1800
    Seller said he bought it several years ago and the welder/power wasn't working. He never got around to working on it and when I got it, the motor wouldn't crank.
    Anyway, motor is now running great. New gas and new voltage regulator is all it needed. Engine idles nicely and when the switch is flipped, it revs to full power. I'm making no progress with the welder/generator. I'm getting no power with the welder or AC outlets.
    Here's where I'm at:
    Flip on power switch and the panel LED lights, and the exciter board (I think that's what it is) LED lights up. It looks to be a new board compared to the other boards. The outer coating of the large capacitor on this board looks like it has melted a little. After cranking, both LED's go out.
    Brushes look good; polished slip rings, resistance between slip rings looks good. Resistance between slip rings and ground = OL
    Main capacitor looks new. Ohms test shows ohms slowly rising up to about 4 M
    The one fuse on the panel looks good and all breakers are good. The other fuse is an inline fuse on a red wire which is disconnected. That loose wire, along with 2 loose black wires are on the left of the machine near the rectifiers.
    AC voltage across the 2 black wires is .5 V at idle, and approx 2 V at full RPM. I'm assuming these 2 wires go to the SCR bridge since the 2 AC terminals on it have nothing attached.
    It looks like 2 rectifiers below the SCR bridge. One of those has a terminal with nothing attached. I'm assuming the red wire w/ fuse attaches here. The red wire has no DC voltage on it.
    One of these rectifiers has a loose wire leaving it and heads toward the bundle of wires coming from the generator. It ends with a male plug. Coming out of that bundle of wires from the generator, is 2 loose wires. One has a male plug, one has female plug.
    The only manual I could find and reference is for models beginning w/ KA which are models with the AC option. Mine is DC only. I've attached a few pics of the back of the panel where the wires are loose.
    Any help would be appreciated.
    Thanks!
    8,101
    All those wires have numbers on them making it pretty easy to tell where they went by simply looking a an owners manual or the machines wiring diagram which should be on the inside of one of the covers.
    May 2012
    7
    **** cruizer, you're a freaking genius! Who would have thought to look at the back of the panel! < slapping self on head >
    I've been looking at the only manual I've found online for the TB 250G and I knew it wasn't close.
    Any chance you might have manuals for this old of a machine?
    Thanks again!
    Lodi, CA
    1,302
    Look above, under the "resources" tab. Entering your serial number, I get a manual dated October 1986, effective with serial number JG018501.
    http://www.millerwelds.com/om/o426_mil.pdf
    1,890
    I had a problem with mine losing power. Working one minute then nothing. It was the exciter board & I was able to bypass it with millers help. Been working fine ever since. The exciter board was only used a couple years then they did away with it. I have the instructions on how to bypass it written down somewhere. If your interested let me know & I'll find them.
    You can also call Miller engine drives as they will help you troubleshoot it.
    May 2012
    7
    Now I'm really feeling like a moron. I called myself checking the resources, that's where I got the WRONG manual from.
    Thanks, that helps alot.
    May 2012
    7
    If you could find them that would be great!
    I have all the wiring back where it belongs. Still no power and the LED on the exciter board remains lit. The manual says when the LED is lit, the excitation field is shutdown.
    Am I correct in assuming, that until the exciter field is restored, no other trouble shooting can take place?
    Thanks again for all the help guys!
    Dec 2010
    355
    Quote Originally Posted by firefight View Post
    did you ever try to plug a drill into the electrical socket and turn it in reverse by hand to re-excite the generator?
    May 2012
    7
    Quote Originally Posted by tommy2069 View Post
    I tried the drill trick with no luck. I'm not sure if that isolates the problem to any one area or just means that trick doesn't work.
    I'm not sure where to go from here.
    All help and suggestions are appreciated!
    1,890
    O/k so here is my notes. For serial # JG018501 thru JJ355008. Circuit diagram SA-112 555. Remove sheet metal to get at upper most board (exciter feild shutdown board PC3) with red light. All you have to do to bypass board is disconnect wire #20, this is "E" on the schematic & wire #29, this is "H" on the schematic. Connect them together & it's done. You can carefully get the connectors out of the plug as I did.
    If you have power now then check your open circuit voltage which should not go higher than about 92 volts with machine set to max & revved up to welding speed. Mine went to 91.
    If OCV is high do a visual on the varister(spelling) (this is also called a suppresssor) which is located on the rectifier. If it looks burned then replace. I have a note here with part # 046819 which is $18 at miller4less.com. I checked now & this is a good #.
