I have been using a 6" table grinder for my tungsten. Basically, this was how i learned to TIG weld. However, this week i have seen a major difference in my welds when I used a new wheel. So, I am wondering how much money I should invest into a better grinding system? I do not have a ton of money laying around to blow on this. Buy, if there is a HUGE quality improvement then I will need to weigh the pro's on cons.
I am mainly welding 7005 Aluminum Tubing with a Diversion 165. I do not weld a lot of hours in a month. Maybe 15 to 20 hours at best.
What is the best value for tungsten grinding?
Your advise is grearly appreciated
Results 1 to 10 of 18
Thread: TIG Tungsten Grinding
05-02-2012, 09:21 PM #1
Member
- Aug 2010
- 75
05-03-2012, 04:17 AM #2
You can either buy a tungsten grinder which is most likely best but more money or a cheap bench grinder with a new wheel that you don't use for anything else.
MM250
RCCS-14
05-03-2012, 09:44 AM #3
Member
- Aug 2010
- 75
05-03-2012, 10:08 AM #4
Member
- Nov 2011
- Edmonton
- 35
http://www.diamondground.com/piranha2tungstengrinders.html
05-03-2012, 07:11 PM #5
Diamond wheels are nice, some shops using grinding wheels will use two grits, a course and fine grit. If you just need to lightly dress the tungsten use the fine grit only.
Or use a medium to course grit to remove any contamination that might be on the tungsten, or to shape a point on a new tungsten, then use the diamond to put on a nice finish
05-06-2012, 04:49 AM #6
- Feb 2012
- 18
It does depend on how your grinding it, a stone with a fine grit would be better, but try to avoid grinding it with the side of the tungsten towards the stone as the grind marks will cause the arc to be more unstable and sort of spiral off the tungsten where as if it's straight likes with the tungsten front on to the wheel it will have a more stable and controllable cone
05-06-2012, 04:58 AM #7
- Apr 2009
- Upstate SC
- 129
Here's what I use, lapidary diamond disks. You need a backing plate, but then you just stick these diamond disks on it. I mounted mine on a motor I already had, but you can use a grinder.
http://www.ebay.com/itm/New-6-Diamon...item5d2fa98641
JDOld Miller Swinger 180 Buzzbox
Miller Diversion 165
Smithy Lathe/Mill
05-06-2012, 08:44 AM #8
- Apr 2012
- 16
if your using a gringing stone,it should be a fine stone. do not use it for regulr steel or anything else. change stones if you must?
i notice that you say your welding aluminum. this is done with high frequency a.c.. the tungsten must form a ball .this is because using a.c. the current changes fron d.c.r.p to d.c.s.p. so do not use dc only. ac only without h.f. if your using steel brush to clean the welds, stop using it. use stainless only. this is because stainless will not fall into the weld and mateial as easy as steel. steel is carbon base aluminum is not. the two a diffenent metals,and have to be treated as such.
the rest is up to you. amps,speed ,arc length.
one last thing ,when welding aluminum use 100% pure tungsten,also 100% argon gas.. yes all that cost more . if you don't follow the right set up.it will cost a lot in repairs.do it righ,t cost a lot less.
05-06-2012, 09:58 AM #9
- Nov 2003
- 2,019
If you are using your Diversion 165.. DO NOT use pure tungsten AND.... DO NOT ball it!!!!! disregard that advice.... it is wrong....!!!!
A 2% ceriated tungsten is recommended ground to a taper 2-1/2 Times
Electrode Diameter lengthwise...
Inverter TIG machines require different tung selection and prep...
refer to figs 9-1 & 9-2 in the owners manual on tungsten...
http://www.millerwelds.com/om/o232895g_mil.pdf
Also refer to resources referenced in your previous threads...
http://www.millerwelds.com/resources...-your-tungstenThe more you know, The better you know, How little you know............................. (Old Estonian Saying)
02-02-2013, 05:13 AM #10
- Feb 2013
- 1
