As the title says ,how big of a trailer can be built on a single axle.
The cargo 180 wheelbase front engine dragster.
Weight,dragster 1400, toolbox,fueljugs,jack,?,?,? for a total cargo weight of 2000?
What I would like to build or buy is a 60" x 20' tilting deck single axle trailer with the axle at the 15 to 17 foot mark. If need be a 5000# axle could be used elec brakes would be ok.
Has anyone seen anything like this. Ive seen vintage photos but nothing new.
Ive been told if I were to build it myself, I'd most likely never get it registered in PA.
Any sugestions???
Frank Aka The Weekend Welder
Results 1 to 10 of 21
Thread: Trailer how big with single axle
04-29-2012, 07:45 PM #1
- Oct 2007
- Milton PA
- 39
04-29-2012, 08:51 PM #2
- Feb 2012
- apple valley, ca
- 20
There isn't any reason you couldn't register that style trailer in pa. Length of the trailer doesn't really matter. As long as you have the legal max rear over hang, axle to rear of trailer, you are fine. don't know pa but most states are 20% over hang.
04-30-2012, 04:18 AM #3
I also don't see why you couldn't register it but check with the authorities. Look at some boat trailers as they seem to be long. Most likely if you add up the weights of the load & trailer you will be at about 3500# so a 5000# axle is most likely the way to go. What is the reasoning behind not wanting a tandem? If it was me that is what I would build.
04-30-2012, 05:25 AM #4
- Oct 2006
- Illinois
- 459
Sounds like some big bucks are going to be resting somewhere it won't be comfortable. Anytime something is on a trailer it does not belong there. I want the best and safest I can afford. I shake my head when I see expensive toys on a junk or small wheel trailer. I would hate to blow a single tire on a two wheel trailer .
04-30-2012, 09:53 AM #5
- May 2011
- Bossier Parish La.
- 384
04-30-2012, 11:01 AM #6
I've never built a single axle trailer longer than 14 feet, my two cents is that with just one axle over 20 feet of trailer the trailer would be not be rigid enough, the placement of the axle at 15 feet would make it extremely front heavy with any load, while u may want a single axle to make a tilt easier on a single pivot point, I would spent a little more money and get tandem axles to make sure my toy is safe
04-30-2012, 01:51 PM #7
- Feb 2009
- Lodi, CA
- 1,126
You can easily find axle/suspension combinations capable of carrying 5, 7.5, 10, or 20 thousand pounds. Just carrying a dragster, I wouldn't consider a problem, just have to engineer the frame to be stiff enough to handle the weight past the axle.
I have a hard time understanding why this is even an issue???
Edit: if you don't like the laws in your state, most states recognize the laws in others,,,,,, that is, you can register a trailer in any other state your state is very likely to accept it. Liability, in all cases, as far as I know, rests with the power unit. Good or bad, that's the way it is. Since just a few years ago,,,, road taxes and weight fees are also mostly (if not always) assigned to the power unit also.Last edited by JSFAB; 04-30-2012 at 02:06 PM.
04-30-2012, 04:55 PM #8
http://www.gregspradlin.com/blog/vin...agster-photos/
Hey i have 2 vintage Goodyear Blue Streak slicks. Had them on my '33 Ford in high school...BobBob Wright, Grandson of Tee Nee Boat Trailer Founder
04-30-2012, 05:59 PM #9
- Oct 2007
- Milton PA
- 39
this is what I had in mind
some picks of what I had in mind.
04-30-2012, 06:39 PM #10
