Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    wisconsin
    116
    Looking good.
  2. #22
    1,928
    If you weld 1/4" x 4" flat bar under your table top it will warp. You can weld it to the legs & then just a couple small welds to the top to minmize warpage. SI would suggest using angle & only tacking it on with small welds.
  3. #23
    Mar 2011
    19
    Won't do that then, I'll leave it the way it is right now. Just finished the shelf.
  4. #24
    wisconsin
    116
    Looks good.
