Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Mar 2011
    19
    Cool Setting up my place
    I'm setting a place (about 20ft x 30ft). I'm gonna have two tables, one movable and the other fixed, also have plans for a portable work station I found (was made from wood over a steel frame).
    Movable table (1/2" top 24" by 48")
    Fixed table (1/4" top 29" by 50")
    Work Station (29" by 25")
    Maybe will do smething like this:
    3,959
    What kind of fabbing will you be doing?...Bob
    Mar 2011
    19
    Will start with 4-5 of this:
    Or this one
    3,959
    Quote Originally Posted by GilNewWelder View Post
    Or this one
    Cool. Need some of these???...Bob
    1,919
    In the picture labled fixed table I see a huge fire hazard. Lots of stuff on the shelves that are most likely flammable. Make sure you know where your sparks from grinding, cutting, etc. are going. Get a few extinguishers.
    Good luck with the first "job".
    Mar 2011
    19
    Thanks for the comment but the table was outside the room when I took that picture. The room I'm going to use is empty right now because need to set up some pegboard to hang some c-clamp, etc. Thanks again
    P.D. Will get some Fire Extinguisher also
    1,919
    It looks like a basement. Do you have ventilation in the room to the outside? A must when welding a lot. You'll also need make up air. Concrete walls & floor are good.
    Mar 2011
    19
    Yep, I'm working on that also
    wisconsin
    116
    Looks like it will be a nice place to work.
    Jan 2012
    Metro Detroit, MI
    185
    Looks great man the only thong thay giys me is you.meed braces on the bottom.of the fixed table or over time due to heat and weight it will warp. I really like it though I wish I had a vise and bench grinder on a floating table.
    Never Satisfied
    Millermatic 211
    Maxstar 150STL
    Metabos
    Kennedy Maintenance Pro Full
    Makita Cordless 18v Li-Ion
    Stihl TS 420
    Timfrank88@live.com
