    Apr 2012
    Default Aluminum Fabrication
    Hi Guyzz..
    I would like to know about the Aluminium fabrication..Is there rusting will take place if this fabrication done?Which is the best service provider for the fabrication in Toronto area?
    Aluminum doesn't rust....
    3,937
    Quote Originally Posted by Diversion180beads View Post
    It just turns to a nice white powder...Bob
    561
    Aluminum still needs treatment, just like steel, for protection from the environment. Aluminum needs to be anodized or painted/powder coated.
    Kevin
    Jan 2012
    Kansas
    85
    Quote Originally Posted by Anal123 View Post
    Aluminium fabrication is mostly used in hard shops like welding and other this type hard shops because the Aluminium fabrication is hard and strong
    What? Hard shops?
    Aug 2012
    Ontario, Canada
    I work with aluminum everyday, and I agree with paint or powder coating. Because aluminum in a non-ferrous metal it oxidizes very quickly. Also if you ever have to different types of metals or alloys in direct contact with each other this effect will happen much quicker. Make sure your aluminum is clean before welding, wire brush the jeepers out of the weld zone before welding.
Tags for this Thread
