Results 11 to 19 of 19
    Jun 2006
    Maine
    732
    double post.
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
    asheville n.c.
    618
    Quote Originally Posted by GilNewWelder View Post
    This one is very nice
    makita. We have 2 of them evolutions we tore to pieces very shortly
    May 2012
    215
    Default Framing saw to cut through metal???
    Everyone has there own opinion of course . I work in a fab shop we have several of the metal cutting saws. Skill mags and another brand. They are ok if you take the time to clamp down a straight edge ...... Make sure you clean out the shavings trap after each use . Now I think using a skill saw with a metal blade works about the same . They both pretty much suck and are so loud . I use a track torch or my trusty burn bar and use a torch for half inch and up and a plazz cutter for 1/16 up to half . I cut some two inch plate last week with a track torch and number three tip. Then I finished making the final cuts by hand with a torch with number two tip and my helper holding a rose bud ahead of my cuts...... It looked great .
    May 2012
    Oostburg, WI
    34
    Quote Originally Posted by CharleyL View Post
    Wood cutting saws are really too fast for cutting metal. It will work, but the blade suffers with shorter life and doesn't cut as well at that speed. You should purchase a metal cutting saw. They have a lower blade speed and do the job well.
    Charley
    Do you have to change the blades of saws if you go from mild steel to stainless or aluminum so that the saw blade doesn't cause it to rust? I know you have to change grinding pads if you're going from mild steel to stainless or aluminum.
    May 2012
    215
    **** no
    Mar 2011
    19
    Quote Originally Posted by beamwalker View Post
    Which type of blades do you use on the MAKITA?
    May 2009
    Central North Carolina
    150
    We haven't cut any stainless yet, mostly mild steel. I did cut some aluminum for a couple of small projects and didn't experience any problems. A light spray of PAM cooking spray on the blades when cutting the aluminum helps keep the blade clean. After normal preparation the aluminum pieces TIG welded fine. Saw blades remain quite clean when compared to grinding disks. With grinding disks you get metal chips embedded into the disk, and they can easily get transferred and mixed into the surface of other metals. This doesn't happen with saw blades, drill bits, milling cutters, or lathe tooling.
    If you don't guide these metal cutting saws and you try to free-hand cuts as you would a sheet of plywood you will tear up a metal cutting saw blade in a very short time. These blades will last for hundreds of cuts if you don't bind the blade in the cut or stop in the middle of the cut and then try to resume. The metal will work harden and dull the blade when you try to resume the cut. It only takes one bind or hardened metal spot to ruin a blade. Avoid cutting rebar or hardened metal with these saws. Use abrasive blades for this type of work.
    Charley
    ______________________________
    Miller MM252
    Miller Bobcat 225NT
    2 O/A torch sets
    Milwaukee 8" Dry Cut Saw
    Milwaukee 9" Grinder
    2 Milwaukee 4 1/2" Grinders
    Wallace 5 Ton Gantry
    Too many hand tools
    Cave Creek Az
    1,084
    Don't buy the Evolution saw. I bought one early this year for a job and have used it quite a bit. It rattles itself apart, pars are continually falling off of it, and the the cheesy plastic miter gauge/lock thing slips. The blade height adjuster also slips about every other cut. I have no tried other brands, so can't reccomend another one though.
    May 2009
    The Colorado Gas Patch
    185
    Save your money.
    Buy a small plasma torch put a drag shield on it then use a straight edge.
    Save more money,
    Buy the circle cutting attachment for the round holes.
    Once you go plasma you don't look back!
    Steve
    Bobcat 250EFI
    Millermatic 350P
    Hypertherm 1250
    A Bunch of tools
    And a forklift to move the heavy stuff with..
    Torchmate 2x2 CNC Plasma
    It's Miller Time - Get Back To Work!
