I'm thinking to get me a framing saw to cut some steel, I read that the framing saws with a Diablo steel blade are good. Up to which thickness I can use this method?
Homedepot's Ridgid 6 1/2" VS Harbor Freight 7 1/4" Chicago Electric?
Results 1 to 10 of 19
04-26-2012, 08:55 PM #1
- Mar 2011
- 19
Framing saw to cut through metal???
04-27-2012, 07:53 AM #2
- May 2009
- Central North Carolina
- 133
Wood cutting saws are really too fast for cutting metal. It will work, but the blade suffers with shorter life and doesn't cut as well at that speed. You should purchase a metal cutting saw. They have a lower blade speed and do the job well.
Charley______________________________
Miller MM252
Miller Bobcat 225NT
2 O/A torch sets
Milwaukee 8" Dry Cut Saw
Milwaukee 9" Grinder
2 Milwaukee 4 1/2" Grinders
Wallace 5 Ton Gantry
Too many hand tools
04-28-2012, 02:14 PM #3
- Dec 2010
- yuma az
- 66
hmm
don't know about those two but a skill mag77 with a carbide tipped blade will cut right through 1/2inch ply and a steel sawhorse like butter don't ask how i know
04-28-2012, 07:45 PM #4
- Mar 2011
- 19
This one is very nice
04-29-2012, 12:01 PM #5
- Mar 2011
- 19
04-29-2012, 12:46 PM #6
- Oct 2006
- Illinois
- 474
What gauge or thickness are you cutting ? I bought the HF STEEL cutting circular saw and it is good. I don't need the big buck real saws so the HF it was. I got it for around 60.00 with coupon and it paid for its self already. I was going to buy the Milwaukee but it would have been almost 200.00 more. I used it for cutting 12 and 18 gauge plus 1/4" plate. I cannot complain. If you need it every day then go for a real steel cutting saw. good luck
04-29-2012, 03:24 PM #7
- Dec 2010
- yuma az
- 66
hmm
not sure bout the power of that saw i was talking about one of these skill mag77 worm drive
http://www.google.com/url?sa=t&rct=j...E_3MUoxcmV4C5w
04-29-2012, 04:53 PM #8
- Mar 2011
- 19
04-30-2012, 06:56 PM #9
- Sep 2009
- Key Largo, FL
- 21
Steel cutting saw
I have the saw listed below, I cut 1/2" mild steel with it a lot. It will cut bigger but I haven't done it yet. The key is lock a straight edge on the edge for a guide so it doesn't bind. Blades are 85 buck or so and use the manfact recommended. It has saved me lots of time!!
Milwaukee 6370-21 13 Amp 8-Inch Metal Cutting Circular Saw.
05-04-2012, 06:51 AM #10
1/8" and up is too thick for a wood circular saw. That being said, I have cut THOUSANDS of feet of 26ga steel sheeting with my makita 7 1/4 circular saw. If you can find them, the Tenryu metal cutting blades are much better and last longer than the steel demon. For wood though, every one of my saws has a red diablo blade on it.
For 1/8" up to 1 1/2" bar grating I use my Champion metal cutting saw. http://www.championcuttingtool.com/pdf/rs725.pdf
my only complaint is that is uses a blade with a weirdo 20mm arbor hole.Bobcat 225NT
Cutmaster 52
Lincoln Weld-Pak 100 buzz box
Caterpillar TH63
'07 Kawasaki ZZR600
