Results 1 to 8 of 8
    Jul 2009
    Fl Keys
    3
    Default Miller Dynasty problem
    I have a dynasty 200 DX, today turned it on and the help display came on,
    HEL P21. Have anyone on the forum ever had this problem?if so does it have
    to be sent to a service agent to be repaired? Where is the service agent in
    South Florida.
    Thank you for any info you can give me Jim
    Oct 2008
    Central California Coast
    302
    :~ATTITUDE MAKES THE DIFFERENCE!!!:
    Oct 2004
    Edmonton, Alberta
    8,197
    Quote Originally Posted by Gremlin View Post
    South Florida.
    Did you try to run the machine BEFORE the self check had cleared??
    Aug 2010
    Los Angeles
    1,170
    Mine comes up HELP 10 when that happens. I have to shut down and restart with the contactor off.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Oct 2008
    302
    South Florida.
    This is what I found in the manual:
    11 Help 21 Display
    Indicates voltage or current feedback has
    been detected with contactor off. Contact a
    Factory Authorized Service Agent if this
    display is shown.
    Jul 2009
    Fl Keys
    3
    Default Sent Dynasty to repair shop
    I sent my Dynasty to a repair shop recomended by Miller Tech. I purchased the machine 2/09 and have only welded about 100 to 150 ft. on aluminum usually
    1/8" plate or rod 1/4" to 3/8" on metal art projects. Has anyone ever had a Dynasty given them any problems with so little use? Sometimes it will sit for two months without being turned on. It always worked perfect to this point.Any feedback from Dynasty users will be appreciated.
    Thank you Jim
    Sep 2009
    Key Largo, FL
    24
    Default Factory reset
    Mine did that once, look up how to do the factory reset.
    Dec 2011
    20
    South Florida.
    Mine had a some problem almost simillar .It displayed help-1
    I latter figured out that the problem was being caused by a loosened
    earth nut .take a spanner and tighten all the nuts at the earth clamp.
    Good luck!
    Powerweld
