Results 1 to 10 of 18
    Apr 2012
    10
    Default Skid Steer Boom attachment
    Skid steer boom attachment project.
    I looked at buying a boom attachment for my skid steer but thought it would be easy enough to build and I could do my own design.
    Bought a blank 3/8" bobtach plate and 7ft or 4X4X.250 tube and welded it at a 45 degree angle to the plate. Then closed in the sides and top to add strength as well as 2 of the 2X2X.188 tube braces. I have a heavy 1/2 inch thick lift plate on the bottom and a 2 inch reciever for trailer drawbars on the top. Also built a 13ft 3X3X.250 piece and attached a 3 ft gantry to that at an angle. With the 13ft tube inserted into the 4X4 I have 24ft of lift and can lift 500lbs out at the far end. So I could lift rafters up to that height etc. One
    of its first jobs will be putting a new diesel motor in a friends sailboat where that reach is needed.
    northern NJ
    1,897
    Can you really lift 500 pounds from that boom extension without lifting the back tires?
    MM250
    RCCS-14
    Salem ,Ohio
    3,948
    Cool
    Was wondering the same thing without counter weights or out riggers...Bob
    Jan 2012
    Metro Detroit, MI
    185
    That is pretty sweet if I was at work I would take pictures of some of the skidsteer attachments I have made. Now all you need isto fabricate some removeable counter weights.
    Never Satisfied
    Millermatic 211
    Maxstar 150STL
    Metabos
    Kennedy Maintenance Pro Full
    Makita Cordless 18v Li-Ion
    Stihl TS 420
    Timfrank88@live.com
    Apr 2012
    10
    Yes, as long as you don't take it up really fast.
    I was a bit surprised it lifted that much out there as well.
    It is a S185 with the extra 100 lb counterweight.
    Looks good...gonna build one for mine...
    Feb 2012
    wisconsin
    116
    I built one for a friend of mine, he uses it to load scrap.
    Is that on a 45 degree angle??
    Feb 2012
    wisconsin
    116
    He said in thread its on a 45 degree angle.
    Apr 2012
    10
    Quote Originally Posted by Diversion180beads View Post
    Yes it is attached at a 45 degree angle.
