Results 1 to 10 of 18
    Apr 2012
    10
    Default Skid Steer Boom attachment
    Skid steer boom attachment project.
    I looked at buying a boom attachment for my skid steer but thought it would be easy enough to build and I could do my own design.
    Bought a blank 3/8" bobtach plate and 7ft or 4X4X.250 tube and welded it at a 45 degree angle to the plate. Then closed in the sides and top to add strength as well as 2 of the 2X2X.188 tube braces. I have a heavy 1/2 inch thick lift plate on the bottom and a 2 inch reciever for trailer drawbars on the top. Also built a 13ft 3X3X.250 piece and attached a 3 ft gantry to that at an angle. With the 13ft tube inserted into the 4X4 I have 24ft of lift and can lift 500lbs out at the far end. So I could lift rafters up to that height etc. One
    of its first jobs will be putting a new diesel motor in a friends sailboat where that reach is needed.
    1,589
    Can you really lift 500 pounds from that boom extension without lifting the back tires?
    3,671
    Was wondering the same thing without counter weights or out riggers...Bob
    Jan 2012
    Metro Detroit, MI
    182
    That is pretty sweet if I was at work I would take pictures of some of the skidsteer attachments I have made. Now all you need isto fabricate some removeable counter weights.
    Never Satisfied
    Millermatic 211
    Maxstar 150STL
    Metabos
    Kennedy Maintenance Pro Full
    Makita Cordless 18v Li-Ion
    Stihl TS 420
    Timfrank88@live.com
    Apr 2012
    10
    Yes, as long as you don't take it up really fast.
    I was a bit surprised it lifted that much out there as well.
    It is a S185 with the extra 100 lb counterweight.
    Looks good...gonna build one for mine...
    wisconsin
    113
    I built one for a friend of mine, he uses it to load scrap.
    Is that on a 45 degree angle??
    wisconsin
    113
    He said in thread its on a 45 degree angle.
    Apr 2012
    10
    Quote Originally Posted by Diversion180beads View Post
    Yes it is attached at a 45 degree angle.
