Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
  1. #21
    Apr 2009
    Upstate SC
    143
    Beautiful fab job, but it looks like the outer cylinders will be running leaner than the middle ones.
    JD
    Old Miller Swinger 180 Buzzbox
    Miller Diversion 165
    1945 Craftsman Atlas Lathe
    Smithy Lathe/Mill
  2. #22
    May 2012
    Oostburg, WI
    34
    Quote Originally Posted by H80N View Post
    and then there is John Marcella's work...... just inspirational
    (borrowed the link from another thread.... visuals are stunning!!)....
    http://weldingweb.com/showthread.php?t=83501
    http://www.yellowbullet.com/forum/sh...28&postcount=4
    http://www.marcellamanifolds.net/images/Images.html
    Thank you so much for posting those links, those beads are awesome, now I will keep practicing until I can create such artistry. This John Marcella is a legend in my book
  3. #23
    Sep 2013
    Langhorne,Pa
    17
    Default Machine
    Quote Originally Posted by foreverAstudent View Post
    Hello,What welding machine are you using?
  4. #24
    Nov 2003
    3,584
    Quote Originally Posted by Engine Builder View Post
    Hope he Has a DYNASTY... because you will never achieve that sort of puddle control with a transformer machine...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
  5. #25
    Feb 2012
    NY
    99
    Great job spence! For your first one you nailed it man! In Ny we have a helium shortage as well. The owner of my lws told me he can get it and couldn't give me a price on a mix but said trust me you wont like the price.
  6. #26
    Apr 2009
    Oswego IL
    758
    Default plenum
    I agree nice work, i worry about the runners running lean on the outside cylinders as the draw of the manifold u built would work well with fuel injection, but im almost certian it will have a lean condtion with a carb on the outside and rich on the centers. Easiest way to confirm this is to to run the car at wot for a minute of so and check the headers with a temp gun. Also unless you really spin that motor ie over 8k, we have never bettar hp with anything other than a victor junior.
    Kevin
    Lincoln ranger 305g x2
    Ln25
    Miller spectrum 625
    Miller 30a spoolgun
    Wc115a
    Lincoln 210mp
    F550 imt service truck
  7. #27
    Mar 2009
    Akron, Ohio
    54
    Very nice work, may I ask what the trick is to laying down a thicker bead? Bigger cup/filler?
    I am new into tig welding and am only using a diversion 165.
  8. #28
    play around with AC balance and AC frequency.
    HTP Invertig221 D.V. Water-cooled
    Eastwood MIG175 w/spoolgun
    Eastwood Versacut40 Plasma cutter
  9. #29
    I guess he's gone... I wish we knew what equipment he was using.
    Killer work for a first manifold... ****, killer work for a 50th...
    Mark
    (aka: Silverback, WS6 TA, JYDog, 83 Crossfire TA, mpikas, mmp...)
    Synchrowave 180 SD | MillerMatic 211MVP + Spoolmate | Hobart Handler 135 | Everlast Power Plasma 50
    1960 Bridgeport J-head | Grizzly 10x22 | HF bandsaw | Rigid 4.5” angle grinder (+2 cheapie HF ones)
    BFH
  10. #30
    By having a removable top section, he should be able to weld in little dams or whatever to even up the flow, maybe.
    why is helium an issue here? I'd have guessed he would want argon.
