I have recentlly bought a new mig and im finding it hard to get the power right. The weld always seems to be big and doesnt melt into the steel even after i turn the power up. Does it have anything to do with the wire speed? Any advice?
Results 1 to 10 of 10
Thread: setting up a mig
04-13-2012, 03:11 AM #1
- Apr 2012
- 4
setting up a mig
04-13-2012, 04:46 AM #2
- Aug 2009
- 136
Have a look at the documents here http://www.millerwelds.com/resources...ur-skills/mig/ They will explain it better than I can.
Ken
04-13-2012, 05:08 AM #3
- Apr 2012
- 4
04-13-2012, 05:11 AM #4
Member
- Dec 2009
- 43
The first thing to learn is how to keep a consistant 1/4 - 3/8 inch arc length. Trim the wire so about 1/4 inch sticks out from the tip and weld a bead using the chart settings on metal in the flat position. Pay attention to keeping the gun angle constant as you go. Move the whole gun along the weld. When you finish the bead look where your gun ended up and how much wire is now sticking out of the tip.
When you can answer that the gun is still at the same angle that I started with and the wire is still sticking out about 1/4 inch you will most likely have a nice weld. But if you are holding and moving the gun right and the weld is tall and thin you are going too fast. If the weld is really wide and maybe even sinking below the surface you are going to slow.
Once all is good using the chart settings on the flat you can move on to trying joints in flat, then you can move to other positions.
04-13-2012, 06:09 AM #5
- Apr 2012
- 4
I find it hard though to adjust the settings to difrent thickness of steel
04-13-2012, 06:26 AM #6
- Sep 2005
- 4,246
The wire speed is the "heat" or power.
04-13-2012, 06:47 AM #7
- Feb 2012
- wisconsin
- 113
As sberry said, the faster the wire speed, the more amperage you have. On 1/4 inch plate start with 21 volts and 375 IPM if using .035 wire. weld a bead or two, then try ajusting speed up and down, and then voltage up and down. when you have good welds, write down settings. Good luck.
04-13-2012, 08:19 PM #8
Post some pictures and give some specifics, that would help a great deal.
Nick
04-13-2012, 08:22 PM #9
Type of welder, wire, gas, settings....
Nick
04-14-2012, 04:08 AM #10
- Apr 2012
- 4
Techarc 310. 1,2,3,4 corse 1,2,3,4 fine and 1-10 on wire speed
