Results 1 to 10 of 13
    Mar 2012
    25
    Default stainless to steel welding
    We are welding cheap stainless ( little bit ferrous) I can feel a little pull from a magnet.. to a 4" galv coated post. We are grinding the galv off & welding with a 70 S6 standard steel wire. Does anyone see a problem with this? we weld steel & aluminum usaully & make these welds maybe twice a month. The welds look good & have good deep penetration. Just curious if this might fail in the future. your thoughts!!
    Deltaville, VA
    2,239
    309 SS wire would be a better choice.
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
    Mar 2012
    25
    With Argon?
    Deltaville, VA
    2,239
    I'd use C25 since the mild steel will rust anyway. The weld bead will be more corrosion resistant than the base metal.
    For SS to SS I still use Tri-Mix for short arc.
    Dynasty 200 DX
    Hobart HH187
    Dialarc 250 AC/DC
    I have been a pipe and tube welder for about 10 years when we make a dmw or dissimilar metal weld we use inconel idk how critical you need to be on your project though
    731
    Quote Originally Posted by Waymack View Post
    What is the advantage of using iconel over SS.
    now Im no metallurgist but from what I understand inconel has a mixture of metals that will weld properly to carbon chrome or stainless this is for high heat high pressure lines now if it's not anything critical weld it with whatever u want if it's gettin painted weld it with carbon
    Mar 2012
    25
    It is a 4" flange to hang an aluminum gate on. welded all 4 sides. gate does not weigh 100 pounds. like I said the welds look good & the stainless is not pure. CHINA CRAP probably. I can fell resistance with a magnet. After we weld we are powder coating the whole pc.
    I did order some 309 ss wire for the future. I just hope what I have out there now will not fail. Any thoughts on this. will they fail?
    3,945
    Quote Originally Posted by solhauls View Post
    I did order some 309 ss wire for the future. I just hope what I have out there now will not fail. will they fail?
    Depends on who is welding them and what gas is being used. Yes it will fail if the weld looks like bird droppings and no they won't fail if the area is prepped properly and the welds are good...Bob
    Jun 2006
    Maine
    732
    What do you mean the stainless "is not pure?" what you're welding to is most likely a 4xx series stainless. 400 series (like 409) are non-austentic and will be slightly magnetic. if you're using ss exhaust pipe... it more than likely is 400 series.
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
