hey guys im just wondering if there is anyway possible if i can give more power to my 125 arc welder through a standard plug in, ive been using 1/16 rods but id like to go higher, in order to do so i need to turn the heat up, but once i turn the heat up i can get a nice arc but only for a few seconds until my breaker goes. i got a 120/240-VAC circuit panel, please any advise would be great!!!!! PS there is no way that i can put a new panel in, because i already have 2
Results 1 to 4 of 4
Hybrid View
04-03-2012, 05:16 PM #1
- Apr 2012
- 1
not enough power in my 125V arc welder
04-03-2012, 06:19 PM #2
- Nov 2003
- 2,019
I think you need to face the inevitable and move up to a 230vac machine...
sounds like you have reached the upper limits of what you can do with a small machine... time to move up.... lots of used buzzboxes on CL Search Tempest for reasonable prices....
http://www.searchtempest.com/The more you know, The better you know, How little you know............................. (Old Estonian Saying)
04-03-2012, 06:38 PM #3
If you still have room on the welding machine to turn up the "heat" then
install a 120v 30amp Circuit-
10g wire & a 30amp Breaker
You didn't mention the size of the breaker you haveEd Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
04-07-2012, 01:04 PM #4
- Jun 2009
- greenfield new hampshire
- 776
H8ON, thanks for the search tempest site, i am always looking for an old pan head on CL, this makes the process much quicker. nice job
