    Apr 2012
    Unhappy not enough power in my 125V arc welder
    hey guys im just wondering if there is anyway possible if i can give more power to my 125 arc welder through a standard plug in, ive been using 1/16 rods but id like to go higher, in order to do so i need to turn the heat up, but once i turn the heat up i can get a nice arc but only for a few seconds until my breaker goes. i got a 120/240-VAC circuit panel, please any advise would be great!!!!! PS there is no way that i can put a new panel in, because i already have 2
    Nov 2003
    2,019
    Quote Originally Posted by Mitch615 View Post
    I think you need to face the inevitable and move up to a 230vac machine...
    sounds like you have reached the upper limits of what you can do with a small machine... time to move up.... lots of used buzzboxes on CL Search Tempest for reasonable prices....
    http://www.searchtempest.com/
    The more you know, The better you know, How little you know............................. (Old Estonian Saying)
    2,636
    If you still have room on the welding machine to turn up the "heat" then
    install a 120v 30amp Circuit-
    10g wire & a 30amp Breaker
    You didn't mention the size of the breaker you have
    Jun 2009
    greenfield new hampshire
    776
    H8ON, thanks for the search tempest site, i am always looking for an old pan head on CL, this makes the process much quicker. nice job
Tags for this Thread
