Results 1 to 10 of 12
    Mar 2012
    Bakersfield, CA
    56
    Default diesel engine oil
    What is the best engine oil for the Mits diesel ?
    Oct 2004
    Edmonton, Alberta
    8,325
    Been using 5-40 synthetic Connoco Triton EC for the last year. Seems to be working well for my customers
    Mar 2012
    Bakersfield, CA
    56
    Add Content
    Mar 2012
    Bakersfield, CA
    56
    Haven't seen that in California how about chevron Dello 5-40 ?
    Oct 2004
    Edmonton, Alberta
    8,325
    You should be able to find shell Rotella. California gets rather warm so stick with a Rotella 15-40
    Mar 2012
    Bakersfield, CA
    56
    Thanks for the input !
    Sep 2009
    Canada
    195
    Most all diesel engines use 15w40, including my F250.
    In winter I go to 10w30 for slightly better starting.
    In extreme cold a 0w30 full synthetic will make sure the motor starts at -40 temps.
    Lincoln Idealarc 250 stick/tig
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
    Owner/Operator Devlin Metal Works
    Custom CNC Plasma Cutting and Welding
    Feb 2012
    apple valley, ca
    29
    You can use any oil that has the api rating for diesel engines. Cj-4 rating
    Feb 2009
    Lodi, CA
    1,313
    I'm in California, I use 15-40 for everything. No confusion, engine oil is engine oil. Back in the '70's and the 80's,,, was even simpler, just use series 3 30w for everything, never once shut an engine down due to improper oil.
    Jun 2010
    Indianapolis Indiana
    200
    Shell rotella t and don't look back
    Miller 330 BPA - Sold
    Miller 180SD Syncrowave - Sold
    Miller Aircrafter 330ST - Sold
    Miller 351 Syncrowave - Sold
    Miller CP-300
    Miller Maxstar 150 STL
    Miller Dynasty 200 DX
    Miller 135 Millermatic
    Miller Spectrum 250D (Now running strong!)
