Results 1 to 10 of 19
    Question Miller Elite helmet issues
    Ok guys im not a big welder by trade but I do need to burn rod from time to tim and until today my miller elite helmet has been nothing but great. I went to weld up some CroMo 4130 tubing today and the issue of my helmet flickering from shade 8-9 and occasionally going back to the grinding shade and going back to the darkened shade but it wont stay consistent and ive run through everything i can think of I switched out the batteries with miller ones from the LWS ive put it out in the sun for a while to charge it ive cleaned the sensors and changed the plastic lens and so far no change in how it acts so im looking to you guys the experts is there something im missing or is it a warranty issue i bought it just over a year ago???
    Leblond Makino mills
    HAAS CNC SL-40 lathe
    American Pacemaker lathe
    wells index mill
    hydrotel rebuilt
    syncrowave 250
    diversion 165
    Miller Elite Vintage USA
    561
    Default Miller Elite helmet issues
    Have you tried the sensitivity adjustment?
    Kevin
    Sep 2011
    14
    May not be the answer you want to hear - Throw it as far as you can and buy a new helmet , just not a Miller. I went thru the same thing twice and to get them fixed cost more than a new hood. Local Airgas dealer said it is a common problem and not worth fixing for the cost. They are good hoods as long as they work .
    Sep 2008
    Dalton, GA
    107
    My Miller Pro Hobby did about the same thing on Saturday. I thought the batteries were dead, changed them out, still it just kind of flickers a little. Mostly just dark.
    Is there any kind of reset or something?
    I hate to have to go buy a new helmet.
    Burt
    _______________________
    Miller 211AS
    Miller 375
    Miller Thunderbolt XL
    http://www.10FtDrillBit.com
    561
    Quote Originally Posted by Swamp rat View Post
    The hood is a little more than a year old it has a 2 year warranty. Don't throw it get it fixed.
    Kevin
    yes I did try the reset button a few times but it is under warranty ill see what the LWS can do for me but if the miller helmet isn't up to spec for you and they wont fix mine what helmet would you recommend I get all I do is tig.
    wells index mill
    hydrotel rebuilt
    syncrowave 250
    diversion 165
    561
    Speedglas has a good hood for low amp tig. Did you check contact points for battery( dirty or bent down ). Is it ok when welding high amps. Also try increasing delay time.
    I Personally have used a arc-one helmet for two years now and never had a problem. But I have tried other helmets. And what I have found is if you are in a position were the sensors are being blocked or your sensitivity is not set right. Flickering occurs. I personally just use a regular non Auto dark hood for tig because it is nicer to have a large being area and also I have never found an auto dark hood that will work properly on tig.
    Nov 2003
    2,019
    Default Battery Issue...
    It may very well turn out to be a battery issue..... I found out when I needed to replace the batts in my BWE..... that due to some quirks in the battery holder design... some batteries will not work reliably... giving intermittant problems that can drive you nuts.... maybe this thread will be helpful..
    http://www.millerwelds.com/resources...g-Window-Elite
    The more you know, The better you know, How little you know............................. (Old Estonian Saying)
    Illinois
    458
    This was posted a while ago and the type of battery that should be used.
    http://www.millerwelds.com/resources...1&d=1312392692
Tags for this Thread
