I have a 330ST Aircrafter in my shop that I inherited when I came onto the project. When I first began using it for TIG a few months ago, I was able to establish an arc from about 1/16" - 1/8" away from my work. Now, for some reason I can only establish an arc by way of a scratch start. Is there a switch or setting I'm not aware of that may have been bumped which might have directly affected this problem? I have downloaded the users manual but can't find anything specific to "scratch start" options.
Thanks,
Casey
Results 1 to 2 of 2
Thread: 330ST Aircrafter arc issues
03-28-2012, 02:30 PM #1
- Feb 2012
- 4
03-28-2012, 03:10 PM #2
- Nov 2003
- 2,019
check figure 3-5 in the manual... make sure that item#7 intensity potentiometer is not turned way down,,,
http://www.millerwelds.com/om/o351h_mil.pdf
check spark gaps and clean/adjust as needed... section 5-3... probably filthy and needing gapped...
Also... check the HF Control switch setting... make sure it is NOT in the center/OFF position..
Page 15 in the manual... figure #4-11 "High Frequency Controls"Last edited by H80N; 03-28-2012 at 03:39 PM.
The more you know, The better you know, How little you know............................. (Old Estonian Saying)
