Results 1 to 10 of 17
    10
    Default TIG Welding Alum base metal wants to spread away from its self
    I keep trying to weld alum and the base metal wants to spread away from its self, Im using ER4043 0.030 alum mig wire and 1/16" er4043, with orange tungsten, The machine is the miller diversion 180, i dont know whats going on, Any help is apperciated, thank you
    Jun 2010
    Indianapolis Indiana
    200
    Picture of said weld?
    Miller 330 BPA - Sold
    Miller 180SD Syncrowave - Sold
    Miller Aircrafter 330ST - Sold
    Miller 351 Syncrowave - Sold
    Miller CP-300
    Miller Maxstar 150 STL
    Miller Dynasty 200 DX
    Miller 135 Millermatic
    Miller Spectrum 250D (Now running strong!)
    561
    More info, amps,tungsten size, balance setting, etc...
    561
    Sorry no balance setting
    10
    Various amp settings im matching amps to material thickness, 3/16" tungsten its what came in the machine, ive tried balling the tungsten, tried keeping it sharp, let me see if i can get pic
    561
    Are you sure about 3/16 tungsten? if so try 1/16. Be sure aluminum is spotless clean. Wipe with acetone, after sanding. Are you inside with no fans or air blowing? You are using argon 100%? Try some 1/16 filler.
    9
    More info as far as metal thickness would help. But, what I've learned about welding alum is to apply more heat off the get go and back off if needed. If you ease into it a lot of times it'll fold away like your talking about. 1/16" is small tunsten unless your welding thin gauge alum. , you'll be going through it quickly.
    561
    Thought op said 1/16 aluminum
    Upstate SC
    143
    For a Diversion 180 you should be sharpening your tungsten, not balling it. And surely you mean 3/32 dia.
    CG
    Old Miller Swinger 180 Buzzbox
    Miller Diversion 165
    1945 Craftsman Atlas Lathe
    Smithy Lathe/Mill
    Deltaville, VA
    2,239
    Have you already developed proficiency in welding mild steel coupons?
    Lot to learn.
    Starting with aluminum may well slow the developmental process.
    3/16" tungsten won't fit in any torch that comes with the Diversion.
    Aluminum likes to be welded hot and fast.
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
Tags for this Thread
