Results 1 to 10 of 12
    Default too much spatter
    what causes exsesive spatter when mig welding? im using a miller 211 and there is a ton of spatter rather large dingle balls too. ive watched videos and they seem to weld with very little spatter and no clean up. when i weld i gota knock off a bunch of dingle balls. how do i dial in my machine like that?
    3,937
    Quote Originally Posted by slow50 View Post
    What Gas? Turn your V down a little...Bob
    Raymore Missouri
    1,920
    Not enough info...what wire, gas, what are you welding, etc. Or you will get walked on here sorry to say
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Default spatter
    Myself I run mainly c-10 sometimes c-25 at around 20 psi. Bit it sounds like a volt wire issue try turning your volts or heat up a little and your wire speed down.
    ARMOR
    MOBILE WELDING&SERVICES
    Trailblazer 302
    X-TREME 12VS
    Spoolmatic 30A
    Millermatic 135
    WeldCraft WPseries TIG torch
    Smith oxy set.
    Nov 2003
    3,435
    there is a lot of info in the MIG resources section..
    think you will find this useful..
    a little bit of reading will solve a lot of problems..
    http://www.millerwelds.com/resources...ur-skills/mig/
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Jun 2009
    greenfield new hampshire
    884
    other way around, turn volts down or amps/wire speed up, this way the weld will run cold, the puddle will fill quickly and with proper angle and stick out, there should be little spatta if you cranked up the volts or lowered the amps/wire speed, the wire would be burning up before it can stabilize in the puddle, leaving droplets of melted wire , spatta, if your settings are right on, gun angle plays the biggest role in how much spatta you get, those little balls of metal scattered all over your work should be in the weld, and will be with practice
    Default cold
    Why would you want to run a cold weld?
    ARMOR
    Trailblazer 302
    X-TREME 12VS
    Spoolmatic 30A
    Millermatic 135
    Smith oxy set.
    Nov 2003
    3,435
    Take a look at the spatter troubleshooting chart Fig 4-1 Page 15 and adjust settings accordingly
    http://www.millerwelds.com/pdf/mig_handbook.pdf
    the rest of the booklet is well worth reviewing too...
    My Blue Stuff:
    3,937
    Quote Originally Posted by armor View Post
    We really don't know if it will be a cold weld because we are missing a whole bunch of info but maybe a few volts down might get rid of the splatter. And since we don't know what he is welding or the settings we won't really know. The only thing we really know is the video doesn't look like that...Bob
    im pretty much dead on the settings on the inside cover. im running hobart .035 wire and co2 argon gas.
