    Dec 2011
    Illinois
    87
    Default stainless to mild steel
    As a noob to tig I was curiouse how would you go about welding stainless to mild steel? Im assuming it is possible no? Being that they both are welded in DC mode that is and would you use your mild steel filler or would you go with the stainless filler? that is if it is possible.
    Thanks in advance,Eric
    561
    DC- 309 filler
    Dec 2011
    Illinois
    87
    Thanks for the reply much appreciated.
    Apr 2012
    16
    Default possible
    Quote Originally Posted by three turbos View Post
    yes it is possible. however the filler rod must be stainless. remember there are different grades of stainless,used in different industries.
    what happens is the weld (stainless) is stronger than mind steel. do not, weld using mild steel,then your weld is weaker than stainless.
    normally an aloy stell and mild steel ,have expansion and contraction rates. that means that they heat and cool differntly. this could cause stress in your weld. so ,if you wish to weld ,using the two steels,preheat and after welding- post heat. that will alow the weld to cool slowley. reduceing the stress,thta may cause,or ,could cause a crack,ok?
