Results 11 to 19 of 19
Thread: Flux Cores getting me down...
03-19-2012, 06:29 PM #11
03-19-2012, 06:30 PM #12
03-19-2012, 06:42 PM #13
- Mar 2012
- 4
drive wheels
I think the Knurled wheels are for a harder wire that
i'm using. Would you suggest u-groove or v-groove?
03-19-2012, 06:43 PM #14
There is a nub on the back of the spool holder, if the spool is not tight to the back it will free wheel and over run the rollers causing a birds nest. I would never run smooth rollers on flux core it will not run with consistent speed, you can not get the rollers tight enough on flux core with smooth rollers with out crushing it and making it out of shape, the reason they don't run smooth rollers on aluminum and flux core!!!
03-19-2012, 07:23 PM #15
I have ran fc on my 252 using .035 wire with the u notched rollers and it works great, but from the sounds of it u definitely need the adaptor to use the 10 lb roll, the adapter is basically just a spacer too keep the roll snug to the wall of the machine so the roll can work as intended, I would strongly recommend checking the wire inlet guide, after a while the wire wears it out and it causes the birds nest effect, more so on fc and stainless, if you are using the plastic one that came with the machine I would recommend upgrading to the brass one
03-19-2012, 08:49 PM #16
- Jun 2009
- greenfield new hampshire
- 776
are you keeping the same distance from tip to work as with short arc, fc likes more of a stick out, from all of the fc that i have ran in the past, if i started it with a short stick out, it will burn into the tip, i used about 3/4" for a stick out, hope this helps, my experience was about a 27 years ago welding ships, not to sure if it has changed all that much
03-20-2012, 04:50 AM #17
03-20-2012, 04:57 AM #18
No not suggesting that at all. When I run .035 wire in my gun with the .045 liner I do have some problems. The .035 flux wire is not as strong as solid which is why it birdsnests. If you are welding say 1/8" & up material switch to .045. You would also need the correct size liner. In general terms with flux core you can step up a size over solid because there is less material since the wire is hollow. So if you would normally use .035 go to .045.
What happens is the wire sticks in the tip & the rolls keep pushing so it is birdsnest between the rolls & where it enters the gun. Make sure your wire guide, rolls etc. are all lined up correctly & the gun is as close to rolls as it can be. You can also try anti-spatter spray on your nozzle.
You also need the spacer to keep the roll of wire tight. It should be a spring but you can even use a pc. of pipe or pvc pipe cut to the right size.Last edited by MMW; 03-20-2012 at 05:33 AM.
03-20-2012, 03:45 PM #19
