No sorry with cast iron mig wire. It has the same properties of stick rod drawn out for mig wire. I love it and thats why i bought it for odd jobs just like yours. Seems like i get some every now and then...Bob
http://www.crownalloys.com/TechSheet...ew_Warning.pdf
Results 11 to 20 of 28
Thread: TIG welding Cast Iron
03-19-2012, 05:31 PM #11
03-19-2012, 05:31 PM #12
03-19-2012, 05:33 PM #13
- Nov 2003
- 2,019
03-19-2012, 05:34 PM #14
- Nov 2008
- 24
Sundown: You are absolutely correct - any change in the number of "Ports" will drive a reduction in the size of the orifice and a corresponding change in the air shutter adjustment. I have researched this aspect of the project and know exactly what size orifice will be needed based on the number of "Ports" I block.
Thanks for bringing this up - some folks may not understand the importance of the orifice & air shutter .
03-19-2012, 05:36 PM #15
03-19-2012, 06:02 PM #16
- Nov 2008
- 24
I guess I should have included a little more information when I started this thread. The burner is on a "Commercial" style range. It has six of these burners each having a maximum Btu output of 23K Btu. Being on a range it has a very high quality adjustment valve for each burner that has a large range, is linear and smooth. The issue is it won't go low enough.
I have it adjusted where the outer ring has very few "Ports" burning on low and it is still too hot for a low simmer. On low there is a separate "Low End" adjustment you make to the valve (Like an idle mixture screw on a carb). I can adjust it so low that flames will go out. Bottom line is the burner cap has too many ports for very low temperature simmering. What I am trying to do is take one of the burners and make it into a low temperature "Simmer Burner".
One of the folks on a forum I frequent has blocked the two outer rings using Permatex Muffler and Tailpipe Putty. It works but looks like crap!
03-19-2012, 07:06 PM #17
- Oct 2006
- Illinois
- 460
Not being a smart as$ but did you take gas pressure readings ? Could it be a regulator adjustment upstream of the equipment ? just thinking. We had a gas service where the local Gas supplier upgrade the meter and pressure and the inside regulators were now on the high side {still within limits** so we had to drop down pressure to match equipment specs. Just curious.
03-19-2012, 08:20 PM #18
- Nov 2008
- 24
Not a bad question. But no I have not measured the pressure as it exits the meter/regulator. However the range has it's own internal regulator and it appears to working normally.
The real issue is the basic design of the burner. The manufacturer (Capital) has tried to make one burner do it all - from ultra low simmer to mega heat. This range has the hottest burner (23K Btu) of any residential range. All of the other upper end ranges use a dedicated simmer burner. This issue has been brought up to the manufacturer and I am told they are working on a "Solution".
However, since being a hot rodder and welder since the 60s I figure I can do it myself, better. Additionally, doing stuff like this is fun.
I do appreciate the recommendations and suggestions.
03-19-2012, 10:15 PM #19
- Mar 2007
- Deltaville, VA
- 2,241
Shark,
You say that the "ports" are .10" in dia. That makes them too large for a ight fit for 3/32" SS filler.
If it was mine, I would drill out the holes to 7/64 (1/64 shy of 1/8") and measure the distance from the top of the burner hole to where an inserted rod would seat. I'd then cut lengths of 1/8" 304 SS filler to that length. Insert the filler (tight fit) and then just hit the tops of the filler with the tig arc. The filler is going to melt before the cast iron becomes fluid and seal the hole.
PS. You may have to drill the holes a full 1/8" depending on how the cast drills, but you do want a tight fit.Syncrowave 250 DX Tigrunner
Dynasty 200 DX
Miller MM 251 w/Q300 & 30A SG
Hobart HH187
Dialarc 250 AC/DC
Hypertherm PM 600 & 1250
Wilton 7"x12" bandsaw
More grinders than hands
03-19-2012, 10:52 PM #20
- Nov 2008
- 24
SundownIII:
Thanks for the ideas. If I take this approach with the short pieces of 304 what 200 DX settings would you start with?
