Results 1 to 10 of 19
    TENNESSEE
    75
    Default mig welding aluminized exhaust pipe
    "OUR ONLY LIMITATION IS YOUR MIND"
    Lake of the Ozarks MO
    3,594
    Yes. Muffler shops do it everyday.
    A little extra prep wouldn't hurt the looks tho.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    TENNESSEE
    75
    3,953
    Quote Originally Posted by sickchoppers View Post
    hoe do you know they use aluminized? you ever actually do it?
    I welded alumized for about 8 years when i was working in the sheetmetal shop making ovens for Little Tykes. I made my lathes chip pan from it. No problems welding it. It just sounds different than bare steel...Bob
    TENNESSEE
    75
    3,953
    I welded galvanized last week...had some galvanized conduit....as you weld it flares up like a sparkler~.....its it like that?...i'd like to use this stuff for custom motorcycle exhaust...when you get into unaluminized it gets expensive
    Nope galvanized burns bright white and flares. Alumized is like welding regular steel just a different noise when welding...Bob
    TENNESSEE
    75
    hi ed roz moving to fla cant wait to finally meet you!
    TENNESSEE
    75
    West Farmington, OH
    746
    I used to work at a shop where we did aluminizing and I used to bring my headers in to aluminize them before installing them. If you want to make an aluminized exhaust for a bike you should build the system and finish grind your welds then aluminize the pipes.
    We would always sandblast the parts we were going to aluminize first with extra fine blasting media. Prior to blasting we'd wipe them down with acetone to remove any oils from machining and such. We would always preheat the parts a bit before we actually sprayed the aluminum on them.
    The reason I say aluminize after you weld the pipes up is because you'll burn the aluminum off in the area you weld and will be prone to rusting in the area of the weld.
    This is a you tube video of aluminizing an exhaust header. http://www.youtube.com/watch?v=gbLHCcCegwQ
    Used equipment
    http://www.metalspraysupplies.com/eq...-equipment.htm
    The one I used is like the spray jet 88.
    New equipment
    http://www.imccoating.com/flame-spray-gun.htm
    I don't know how much aluminizing you could expect to do but if there's no one in your area that does it, it could prove to be a worthwhile investment in the equipment to start doing it as part of your business. I know there are a lot of gearheads in my area who'd love to get their pipes aluminized after welding them up.
    Blondie (Owner C & S Automotive)
    Miller 340A/BP
    Victor O/A torches
    Lincoln SP125
    Too many other tools to list
    03 Ram 1500
    78 GS1000
    82 GL1100 Interstate
    3,594
    yea I did. I leased a muffler shop for a year that was doing a good business already.
    OEM's used aluminized from the factory before everyone went to stainless.
    Miller WC-115-A
    Miller Spectrum 300
