Heres a pic of one i built a few years ago. Its got a 30 ton cylinder on it and nothing has budged a bit.
Results 21 to 28 of 28
03-10-2012, 10:56 AM #21
- Feb 2009
- Uxbridge, Ontario
- 19
Miller Syncrowave 180
Millermatic 251
Thermal Dynamics 51 Plasma
Wolfpac 175
Etc.
03-10-2012, 02:51 PM #22
- Sep 2005
- 4,247
Good, certainly well beyond sufficient.
03-10-2012, 03:10 PM #23
- Mar 2012
- 16
03-10-2012, 03:15 PM #24
- Mar 2012
- 16
Thanks, I didn't know about the use of towels etc.. for dampening the break. I tried the cylinder method using a 12' pole but it didn't budge.
We just got done heating it up w/ oxy + acet + rosebud tip, with a come-along and sledge hammer. It was out 1.25" and we got it back .25" after a lot of effort. Nothing was working so we quenched the inside of it with water and it sucked back over. It ain't perfect but I can work with it or cut the ****ed thing off and start over.
03-10-2012, 08:02 PM #25
- Nov 2009
- N.E. IL
- 22
03-11-2012, 06:04 AM #26
That looks amazingly like my wood splitter.... My uncle built it back in the mid 70's and it still runs strong to this day....
If the OP's splitter was mine... I'd just cut off the backstop plate and weld on a stub beam of similar size to the main beam. problem solved.Bobcat 225NT
Cutmaster 52
Lincoln Weld-Pak 100 buzz box
Caterpillar TH63
'07 Kawasaki ZZR600
03-11-2012, 07:06 AM #27
- Sep 2005
- 4,247
03-24-2012, 10:12 AM #28
Personally I would gouge out the face of the plate, place a couple good BFH swings til its where i want it and weld solid. Then take a couple semi circle pieces "the length of the plate" and weld them solid on the back.
