Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Feb 2009
    Uxbridge, Ontario
    19
    Heres a pic of one i built a few years ago. Its got a 30 ton cylinder on it and nothing has budged a bit.
    Miller Syncrowave 180
    Millermatic 251
    Thermal Dynamics 51 Plasma
    Wolfpac 175
    Etc.
  2. #22
    4,474
    Good, certainly well beyond sufficient.
  3. #23
    Mar 2012
    16
    That's a proper beam!
    Quote Originally Posted by UpperCanadaTree View Post
  4. #24
    Mar 2012
    16
    I'd heat it up, use a chain and pull it with the hyd cylinder. But throw an old beach towel or bed sheet over the middle of the chain. If the chain breaks, the towel will dampen any recoil. Also, if you are worried, attach a small rope to the hyd valve so you can stand out of harms way. If you break the chain it isnt anywhere hot enough.
    Thanks, I didn't know about the use of towels etc.. for dampening the break. I tried the cylinder method using a 12' pole but it didn't budge.
    We just got done heating it up w/ oxy + acet + rosebud tip, with a come-along and sledge hammer. It was out 1.25" and we got it back .25" after a lot of effort. Nothing was working so we quenched the inside of it with water and it sucked back over. It ain't perfect but I can work with it or cut the ****ed thing off and start over.
  5. #25
    Nov 2009
    N.E. IL
    22
    how about something like this.
    IBEW electrican 26 yrs
  6. #26
    Jun 2006
    Maine
    732
    That looks amazingly like my wood splitter.... My uncle built it back in the mid 70's and it still runs strong to this day....
    If the OP's splitter was mine... I'd just cut off the backstop plate and weld on a stub beam of similar size to the main beam. problem solved.
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
  7. #27
    4,474
    Quote Originally Posted by rvpc View Post
    Yes, exactly, there is no reason the plate couldnt be cut and welded if need be.
  8. #28
    Dec 2006
    Clarksville, TN
    427
    Personally I would gouge out the face of the plate, place a couple good BFH swings til its where i want it and weld solid. Then take a couple semi circle pieces "the length of the plate" and weld them solid on the back.
