Thread: Truck rack
    Apr 2006
    TAXACHUSSETTS
    1,504
    Default Truck rack
    Finished this last week going on a f-350 ,cc/ub after getting sprayed.Material is 3"x1-1/2"x.120 hss.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    1,912
    Does it have a removeable bar across the back?
    Apr 2006
    TAXACHUSSETTS
    1,504
    Yes it is bolted in a storage spot behind the cab in the photo,s.The rear posts are drilled and tapped for 1/2"x1" bolts.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Stover, MO
    14
    nice work!!!
    The secret to life is to live ultimately by one's own hands and one's independent devices
