View Poll Results: Is A Mig Upgrade Worth The Money?
Voters
52. You may not vote on this poll
  • Yes
    42 80.77%
  • No
    10 19.23%
Results 11 to 20 of 39
Thread: Flux Core Wire?
    British Columbia
    500
    Cool Flux core wire
    the best flux core wire out there i think is
    fabco hobart xl-71 .045 and the esab 7100 ultra dual sheild.
    co2 is the only gas i think you could use unless you use a
    self sheilding wire but keep in mind this wire is verrrry smoky
    and also this wire i think has to be run on straight polarity.
    Oct 2005
    Bulverde, Tx
    1,244
    Quote Originally Posted by Darmik View Post
    I reeeeeaaaaalllllyyy don't think he will be using that wire in a 100a, 120v MIG unit.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
    Plainview, TX
    334
    Esab Dual Sheild 7100 Ultra and Lincoln Outshield 71M are flux core wires (minimum dia of 0.035) meant to be used with gas, especially steel mix in 75/25 Argon/CO2 Ratio. The amperage and voltage reguirements to run this wire properly will put it in machines like the MM DVI (on 220V) and larger.
    To use true gasless flux core, IMHO, you need to use that in a machine meant to run that way. I have used some of this type wire in my MM200, to get by until I got regular wire or Esab/Lincoln Gas/Flux back in the machine, put it only worked by running REVERSE POLARITY.
    I think you should invest in a bigger and better machine, like the MM210, get some 75/25 Steel Mix and some Lincoln Outshield 71M in 0.035. Keep some Hobart ER-70S in 0.030 around for lighter work. If you need even smaller wire, get that wire, the proper size rollers and an extra gun lined for the smaller wire for a quick change over.
    I only run 0.035 and 1/8" is the lightest thing I ever weld. Most of the time, its 1/4" to 3/8" with an ocassional 1/2".
    '77 Miller Bluestar 2E on current service truck
    '99 Miller Bobcat 225NT for New Service Truck
    '85 Millermatic 200 in Shop
    '72 Marquete 295 AC cracker box in Shop
    '07 Hypertherm Powermax 1000 G3 Plasma Cutter in Shop
    Miller Elite and Digital Elite Hoods
    British Columbia
    500
    Quote Originally Posted by DDA52 View Post
    then he can use .035
    before we speak we should think if you know that you cant use .045 dont you think sence says try .035 duh
    Oct 2005
    Bulverde, Tx
    1,244
    Ok, I will ignore the obviously childish poke and let you look at it this way. The original question was regarding a 100a 120v MIG unit. Since .035 gas shielded flux core has a range of 23-28 vdc and amperage range beginning at 125 amps, his machine would never even begin to run the stuff........so why bring shielded flux core up?
    It looks like I did use some sense and actually know the parameters of the wire in question.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    Jan 2006
    Albuquerque, NM
    1,788
    I gotta agree, and I think that for that machine why use any exotic wire when .030 Hobart fabshield 23 is fine and readily available. If he wants to run .035 then Lincoln 211 is available in 4" rolls from the big box stores.
    Regards, George
    Oct 2005
    Bulverde, Tx
    1,244
    Yup, .030 is what he should be using. That would get the max benefit from that machine.
    George, are you still using Fab 23??? Haven't we gotten you away from the darkside and into Fab 21B yet??? The 21B is much better than the NR211-MP even. I was putting down some serious beads on columns with some 1/16 21B on my shop last weekend. We really need to get you away from the darkside...aka the 71T-GS wire and into some 71T-11 wire...the lightside.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    Jan 2006
    Albuquerque, NM
    1,788
    Ok, after xmas (got enough .045 211 to last till Jan next year) but I will see if my LWS has some 21B, don'tcha feel all warm & fuzzy now
    Regards, George
    British Columbia
    500
    Since you know so MUCH...
    PRODUCTS KNOWLEDGE INDUSTRY FOCUS COMMUNITY CORPORATE
    Quick Links Welding Safety myLincolnElectric.com Operator's Manuals Literature Request Service & Warranty Browse Products Careers Welding School AWS Certificates Site Map MSDS Product Registration MotorSports Alloy Surcharge Books & Logo Items Automation Change Country
    Search Product Search Site Search Site Map
    WHERE TO BUY SERVICE CONTACT US HELP QUICK PRINT
    Product Center
    Browse by Category
    Help Me Find
    Search by Keyword
    Recommended Packages
    MSDS
    Certificate Center
    Operator's Manuals
    Power Wave Software
    Welding Library
    Operating Systems
    Pro-Core 100
    K2158-1 PRO-CORE 100 115/1/60
    Here's a compact, portable, user-friendly welder that makes short work of welding chores around the home or farm. Just plug into a 115 volt, 20 amp outlet, and you're ready to go! The easy-to-follow welding procedure chart inside the wire feed access door helps guide you toward all the right choices. Everything you need to weld mild steel with gasless flux-cored wire electrode, plus a "Welding Basics" video is right in the box! Or, add the optional conversion kit(s), shielding gas, and proper solid wire and your Pro-Core™ 100 is ready for MIG welding. Important safety features include Lincoln's trigger control system that keeps the wire electrode electrically "cold" until you press the trigger.
    Advantage Lincoln
    • 30-100 amps output for welding on light to medium thickness materials.
    • Welds up to 1/4 in. steel.
    • Complete, ready to weld package for use with self-shielded flux-cored wire. Upgrades to MIG.
    • Plugs into 115V, 20 amp outlet.
    • Gun trigger safety feature keeps welding wire electrically "cold" until trigger is pressed.
    • Compact, portable, lightweight and easy-to-use.
    (• For welding .035" flux-cored wire) and .023-.030" solid MIG wire (solid MIG wire requires installation of K610-1 MIG Conversion Kit and supply of shielding gas).
    • It's quick and easy to upgrade the Pro-Core 100 for MIG (gas-shielded solid wire) welding. To MIG weld mild steel or stainless steel, install K610-1 MIG Conversion Kit (stainless steel wire sold separately). To weld aluminum, install K610-1 and K664-2 Aluminum Welding Kit. Shielding gas sold separately.
    • Welding procedure chart for mild steel is conveniently located inside wire feed section door making voltage and wire speed selection a snap!
    • Fan-cooled for long life expectancy.
    • Three year warranty on parts and labor. (90 days warranty on gun and cable).
    Physical specifications
    Weight:47 lbs. (21.4 kgs. )
    Dimensions (in) H x W x D : 12 x 9.75 x 16.5
    Dimensions (mm) H x W x D : 305 x 248 x 419
    WHERE TO BUY
    ORDER FORM
    MORE PRODUCT INFO (pdf)
    RELATED ARTICLES
    Description
    Output
    Input
    Processes
    MIG Flux-Cored
    Unit Includes
    • Magnum® 100L welding gun and 10 ft. cable assembly with .035" contact tip installed
    • 10 ft. work cable and work clamp
    • 1 lb. spool .035" Innershield® NR-211-MP flux-cored wire
    • spare .035" contact tip
    • Welding handshield with #10 filter plate and clear glass cover plate
    • Instructional video
    Recommended General Options
    K2275-1 Welding Cart (80 cu.ft. bottle capacity)
    M15445-R Spindle for 2 in. Hub
    K664-2 .035 Aluminum Welding Kit
    Welding Specifications
    Rated CV Output Amps/Volts/Duty Cycle Output Range Wire Feed Speed Range (IPM) Wire Feed Speed Range (M/MIN) Solid Wire Size Range Cored Wire Size Range
    88/18/20% 30-100A DC 50-300 1.3-7.6 .025-.030" .035"
    BACK PRINT
    LOGIN LEGAL NOTICE PRIVACY POLICY DISCLAIMER TERMS OF USE
    ©1999-2006 The Lincoln Electric Company.
    Enough said Darmik
    Oct 2005
    Bulverde, Tx
    1,244
    Enough said Darmik
    I don't think so dude....you need to get your facts straight.
    There is a huge difference between Dual shield flux core and self shielded flux core. YOU quoted XL-71 and Esab Ultra 7100. They are dual shield wires as you stated. They require WAY more voltage than that little unit could ever produce. That is a fact. If you are so sure you are right, call up Lincoln and get them to tell you since you don't believe what you are reading.
    Here are the numbers again.....Hobart XL-71 in .035 has a range that starts at 23 volts and 125amps and goes up to 28 volts and 225 amps. Lincoln Outershield 71M has a range of 20-32 vdc and 90-195 amps. In contrast, the self shielded NR-211MP, which is the wire Linc was referring to in the page you quoted, has a range of 14-16.5vdc and 30-120 amps. THAT is the range of the machine in question, not the others. Now, it may look like the unit would run the 71M wire on paper...BUT anyone who has run that wire will tell you that it gets very jumpy down low. It acts up something terrible. Dual shield wires are meant to be run hot and hotter, not at the lower end.
    This is a totally stupid arguement anyway. Linc would never say that a low end machine would be capable of running a 71T-1/9 wire. When thay talk about flux core, they are talking about NR-211, a 71T-11 wire. That is the wire they mean and they probably even spell it out on the door chart as NR-211MP or 71T-11. They usually won't add a dual shield wire to a door chart until you hit the 251/255 class machines. They have the voltage necessary to run those wires.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
