Results 1 to 3 of 3
Thread: Car Seat Repair
    May 2008
    Troy, MI
    361
    Default Car Seat Repair
    The back tilt mechanism on the seat in my wife’s car failed about 5 years ago. I bought a junk yard seat mechanism and replaced it about 5 years ago. Well it failed again so this time I decided to make a new shaft and weld the existing spline on the end of it to save the $250 cost of a new seat. I kept the weld slightly below the surface so it wouldn’t interfere with the spring. In the process of working on the seat I discovered that the seat frame was also cracked so I fixed it as well. The following pictures document the repair.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Miller Spectrum 375 Plasma Torch
    May 2008
    Troy, MI
    361
    And the rest of the pictures.
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Jan 2007
    Rosetown, SK.
    519
    Nice fix!!
    252 Miller Mig
    180 Synchrowave
    R - 45 Milling Machine
    Kingston 1100 Lathe
    Miller 2050 Plasma Cutter
