Just purchased a Syncrowave DX Tigrunner. i apoligize for my being new and untrained on the tig welding side. been fabricating and welding for 20 yrs but new to TIG. anyway i bought this welder knowing it has a help- 1 code. the local miller repair shop says 3 weeks before looking at it. I havent done anything to it yet. any suggestions (on checks or things i can try to fix ) would be gladly appreciated.
02-22-2012, 12:46 PM #1
- Dec 2011
- 7
Help-1 code on a syncrowave 250 DX tigrunner.
02-22-2012, 01:23 PM #2
- Jul 2010
- 335
If you download the manual from this website and look on page 41 you will see:
Help1 Display
An SCR overcurrent or undercurrent condition has occurred.
Turn power off and back on to correct condition.
02-22-2012, 06:40 PM #3
Unlikely to the above, as the help 1 persists, so your stuck with the problem being the Hall (lem) or problems with the main control board. The are Leds on the board, could tell you more with a serial#
02-23-2012, 03:39 PM #4
- Dec 2011
- 7
firehousefabrication
SERIAL# LH 011624 L
i called miller and he said due to liability he couldnt recommend anything to check in the wiring. a friend said to OHM out the thermistor? any help would be greatly appreciated.Last edited by firehousefabrication; 02-23-2012 at 08:14 PM. Reason: wrong info put down
02-23-2012, 07:36 PM #5
nope, your looking at help"0", my original t-shooting idea still stands
It was born on 1/17/2007
02-23-2012, 08:11 PM #6
- Dec 2011
- 7
you are correct. the HEPL-1 does say An SCR overcurrent or undercurrent condition has occurred. Turn power off and back on to correct condition. so with that any suggestions would be taken and greatly appreciated.
