It all depends on, if you get a permit to do it, if you have enough service amperage to add 50amp, how far you are going to put outlet from the breaker panel, if you have enough Empty breaker spaces in your panel, and so on. Can be as little as $60.00.
Results 11 to 12 of 12
02-21-2012, 12:00 PM #11
02-22-2012, 12:19 PM #12
- Sep 2005
- WY...armpit of U.S.A.
- 636
Installing a 220/240 amp circuit isn't rocket science by any means. The cost will be price of the wire, conduit...if any, breaker and receptacle...if you choose not to hard wire it into the welder. Should you wish to go that route, post back and we'll walk you through it...please provide photos of your panel, the route of the wiring and whether you wish to go Romax, cable or single wiring in conduit.
Miller DialArc 250
Lincoln PrecisionTig 275
Hypertherm 900 plasma cutter
Jet 14 X 40 lathe...ditto
Logan 7" shaper
Ellis 3000 band saw
Lots of dust bunnies
