Results 1 to 3 of 3
    May 2011
    Bossier Parish La.
    560
    Default Welding Table Additions
    This weekend I have been adding receiver hitch type mounts under my welding table. One on each corner for a total of four. I made a platform for the chop saw out of 2x2x1/4" tubing and 1/4" plate. It is recessed down 3 1/4" below the tabletop so the saw deck is level with the table. This way long material is supported by the table while cutting. The other is a chain type pipe vice that was in my shop building when I moved here in 1995. I have not used it till now, as I had no good place to mount it. When I get some more 2x2 tubing I will make mounts for the bench grinder and drill press. I also plan on getting a good bench vice, too.
    I made the receivers from 2.5x2.5x1/4" angle iron welded together. This made the ID 2x2 1/4", but I can add a 1/4" shim if a tight fit is needed.
    May 2011
    Bossier Parish La.
    560
    Default A Few More Pix
    Here's some more pictures of this project.
    Oct 2008
    Central California Coast
    302
    Quote Originally Posted by Bistineau View Post
    Great idea with the chop saw set at table height.
    Good thinking!
    -Ian
    :~ATTITUDE MAKES THE DIFFERENCE!!!:
