Results 1 to 8 of 8
    3,946
    Cool MIG welding cast iron exhaust manifold.
    You guys know how hard it is sometime to weld an old junky exhaust manifold? I have done hundreds of them over the last 34 years most of them stick with Ni rod and some brazed. Some worked well some didn't. So move ahead 30 years i picked up some Crown Alloys .035 44-30 mig wire for cast iron. Its used with Argon and works great. This manifold on my Geo Metro had a crack and it has been hissing for 4 months or so. I drove the car around to warm it up since i wasn't planning to remove it and hit the crack with a die grinder and a stone. Then i dabbed the mig wire in the clean area and triggered it right up the crack. It took about 30 seconds and sealed the crack right up. I let the car run for a few minutes and then let it cool. So far so good. The 2# spool is 75 bucks and i wanted to try it out for a test...Bob
    http://www.crownalloys.com/TechSheet...ew_Warning.pdf
    Dec 2009
    722
    Looks like a miracle wire for cast iron, looks like it does well, with not so clean parent metal. Did you notice any porosity anywhere in the weld?
    I might have to get myself a roll.
    3,946
    The cast has to be clean. I ground where i was going to weld with a die grinder and a stone to shiney metal. The wire stuck perfect to that area. Nope no pin holes. It could have been better if i had more then 2" of room to work in but it was fine...Bob
    Rosetown, SK.
    519
    Keep us posted on how it lasts. New technology is great. Good job , Wayne
    252 Miller Mig
    180 Synchrowave
    R - 45 Milling Machine
    Kingston 1100 Lathe
    Miller 2050 Plasma Cutter
    3,946
    I will watch it since its on my daily driver. I didn't want to try it on someone elses ride first...Bob
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    That is some awesome wire. I bought a 10# spool and it was worth every cent.
    It is so nice to be able to just spot it in quick like that. Much more control than rod.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    West Farmington, OH
    746
    Hi Bob,
    Let us know how it's holding up a month from now. I'm curious. I've never MIG welded a cast exhaust manifold before but sounds a lot quicker than how I've been doing them for a long time now. In the past I've been drilling stop holes at the ends of the crack then veeing them out with a die grinder, pre heating then TIG welding them with some coated 309L filler I've had around for so many years now I can't remember who made them or where I bought them then some post heat and pack in sand to cool. I've not had any problems with this method but yours sounds so much easier and definitely faster especially if you can reach the crack without removing the manifold.
    Thanks for sharing this info with us!
    Blondie (Owner C & S Automotive)
    Miller 340A/BP
    Victor O/A torches
    Lincoln SP125
    Too many other tools to list
    03 Ram 1500
    78 GS1000
    82 GL1100 Interstate
    3,946
    I will watch it. I have been driving the car 80-100 milkes a day for the last week and so far the weld is just fine. It was a stress crack from the exhaust hanging on it and i fixed the broken hanger also...Bob
