Just read the gcr again last night, you only need backer plates if you are bolting the structure to the tub. Thats road racing rules at least, don't know about nhra.
Sam
Results 21 to 30 of 30
Thread: Roll Bar Install
04-12-2012, 01:55 PM #21
- Feb 2012
- Wa
- 320
04-12-2012, 07:14 PM #22
Member
- Mar 2011
- 69
I just checked NHRA again and it's the same...only needed if bolting.
Thanks for the heads up....definately better to double check than to miss something.
05-09-2012, 08:11 AM #23
Member
- Mar 2011
- 69
I have a couple of tubes that meet a shallow angles (nearly parallel) and I've been practicing on the bench how to weld the very inside of the angle. I'm not happy with my current results.
Basically I've been extending the tungsten way out of the cup (about 1") in order to reach into the joint but I'm obviously not getting proper gas coverage and it's a mess.
Any advise on how to do this joint. Been using a size 17 torch with a #6 cup and just cant get anywhere near that joint.
05-09-2012, 08:01 PM #24
- Nov 2008
- 12
Have you tried a gas lense with the longer stick out?
To keep it in the ITW family, here's a bit about use of a gas lense at Weldcraft. http://www.weldcraft.com/2008/01/gas...asics-for-tig/
07-16-2012, 09:09 PM #25
As far as I know you cannot weld chromoly with any thing but tig. A you have to pre heat and be carful not to over penetrate.
07-17-2012, 11:41 AM #26
Member
- Mar 2011
- 69
I switched up to the gas lense and things went much better....what a difference. I'm not certain the job I did would be good enough for an airplane or a 6 second car but for my first go in a car just tickling the required times for a roll bar I'm thinking everything worked out pretty well.
07-18-2012, 10:19 AM #27
- Nov 2003
- 2,019
NOT Correct....
OXY FUEL was the preferred method for many years, long before TIG....
here is an overview of 4130 TIG from the Weldcraft site...
http://www.weldcraft.com/2007/08/tig...me-moly-steel/
How do you think all of those Piper Cubs got built before TIG was invented..??
This is how it was done 70 years ago...
http://www.youtube.com/watch?feature...&v=Q6q1VKsTeKQLast edited by H80N; 07-18-2012 at 10:37 AM.
The more you know, The better you know, How little you know............................. (Old Estonian Saying)
07-18-2012, 10:34 AM #28
- Nov 2003
- 2,019
07-18-2012, 12:16 PM #29
Watching the Piper construction brought back many memories.. As my older brother earned his flying time expense in trade for labor rebuilding aircraft at a local, small airport, I as a young 8 - 10 year old had free run of the place and saw many a disassembled aircraft engines and air frames under repair. The '50s were of a different era before liability lawsuits, etc closed off this kind of access to the younger generations.
As mentioned above, gas welding was the method to build and repair the Pipe chromealloy frames..
my brother in his earlier years...
http://home.4x4wire.com/deddleman/Hal-Piper-J3-s.jpg
Hobby Welder for about 32 years
Hobart 190 MIG with SpoolGun
Hobart AirForce 700i Plasma Cutter
Hornell Speedglas 9000X Helmet
295A AC Buzzbox (what I learned on)
Miller Bobcat 225, factory propane option, also serves as my emergency power generator
Dandeman Dan's Toy Page
07-22-2012, 11:00 AM #30
- Nov 2003
- 2,019
