Hope they get that MM350P sorted out for you.... mine is about 5 years old now and has behaved the whole time.... the MM350P w/25ft Alumapro has been a wonderful setp for my purposes... sorry to hear you are having probs.....
Results 21 to 30 of 52
02-16-2012, 06:40 PM #21
- Nov 2003
- 2,019
The more you know, The better you know, How little you know............................. (Old Estonian Saying)
02-16-2012, 07:07 PM #22
- Feb 2012
- Cool, Ca
- 3
Danno i dont want to hi jack this but a pic says a thousand words right. This probably looks similar to your stuff..
I welded the 2 110v passes first so the plate was hot for the 220v pass but didnt seem to stick
All the beads on the left are run on 110v. The ones on the right are 220v
02-16-2012, 08:33 PM #23
02-16-2012, 08:34 PM #24
02-17-2012, 03:03 PM #25
- Nov 2010
- Oregon
- 41
Update:
Well now I know why I buy American, I get a call from Airgas yesterday afternoon and the factory Miller Tech wants me to call him about my 350P. So I called him today, David is his name and man was he a big help and a stand up guy and knows these machines.
He agrees the feed system needs to be replace and believes that the circuit boards should be replaced and the software updated. He said he is going to next day air the parts to the repair facility immediately! Now that's service, THANK YOU MILLER!
Now with the 211 and spool gun, David says the 211 and gun were ever designed for 5356 ONLY 4043 because of the amperage, he states we would need 220-230 amps to make that wire spray and obviously were not going to get that from the 211 and furthermore the gun is only rated for 160 amps and a 30% DC.
I will accept that.
Then This afternoon I get a call from Ben the Miller Production manager and wanted to know what they could do to make this all right! I said so far they are in my book, I just need my 350P back ASAP, and I have no doubt they will make it happen. He also said about the 211, that their 2012 catalog now says 4043 only.
Miller Electric thank you! Lets see some Chinese company step up like this!
Oh you know what would make this better a 8'-10' Miller Banner for the shop and two 2' long Miller stickers for are shop trailer...
DannoMiller 350 LX Tigrunner
Miller 350P w/XR-Pro
Miller 250MP w/30A spool
Miller 211 Autoset
Hobart Tigwave 250
Hobart Beta-Mig 251
09-18-2012, 08:58 PM #26
- Sep 2012
- 8
eighttrayjourneyman
Sorry to hear of your problems, I will let you know what I have been doing. On my Miller 211, of course you already know aluminum is straight argon or some mix of helium for more heat transfer if you like and can get it, but you dont need it. I am welding 3/16s Aluminum with no problem. Turn wire speed up all the way to 100 and your heat up to 3/8 metal, this throws the wire into a spray mode of sorts and if you hold nozzle about an inch away from the parent metal it goes on well with a little side oscilation. Not bad for such a small machine. Give it a try, its really hot at that setting so experiment with distance from metal with your nozzle. I have been a boilermaker for 40 years Retired. It works well for me. Let me know hope this helps
09-18-2012, 09:06 PM #27
- Sep 2012
- 8
09-18-2012, 09:22 PM #28
- Sep 2012
- 8
eighttrayjourneyman
Hey Danno
I can sympathize with your problems. I have an answer that works well for me I will give you all the parameters that work with my 211. Of course run on 240/220 volts using straight argon 030 wire 4043. wire speed all the way up to 90 or 100 depending on your taste. Use the setting of 3/8s metal that throws the little 211 into a spray mode of sorts hold nozzle about 1inch away from parent metal to keep from frying tips and it does fine on 3/16s aluminum for me. I hope this helps, I am a retired boilermaker of 40 years, I fought it for a little bit but this works well for me hope it will for you .
09-19-2012, 08:10 AM #29
Trailblazer® 302 Air Pak™
Miller Dynasty® 350
Millermatic® 252
Syncrowave 351
SuitCase® X-TREME™ 12VS
Millermatic® 211 Auto-Set™ w/MVP™
Spoolmate™ 100 Series
Diversion™ 180
Spectrum® 625 X-TREME™
09-19-2012, 09:16 AM #30
- Nov 2010
- Oregon
- 41
Miller 211 Autoset
Hobart Tigwave 250
Hobart Beta-Mig 251
