Results 31 to 40 of 52
09-19-2012, 08:13 PM #31
- Sep 2012
- 8
eighttrayjourneyman
09-19-2012, 08:19 PM #32
- Sep 2012
- 8
Spoolgun
Use those settings on your spoolgun and go from there or just leave it there, but its been my experience not too many people weld alike, but that should get you close enough to continue on your own, I actually believe this little machine will handle at least out to 1/4 for sure maybe more.
09-20-2012, 09:39 AM #33
I refused to leave my LWS one day till they coughed up there new nascar power of blue canvas banner! I beat them through attrition and won. Nicest miller banner ive ever seen. If interested ill post a pic after work!
09-28-2012, 07:40 AM #34
I just got my Series 100 Spool Gun yesterday. Having previously read the tips in this thread, I still burned through a couple tips using the techniques advised here.
I'm using .030 4043 wire and 100% Argon.
Last night I had a welding instructor tell me to try turning the heat down to 1 and adjust the wire speed from there. I'll try that in a couple hours and post my results. The one thing I did forget yesterday was to check my wire tension.Trailblazer® 302 Air Pak™
Miller Dynasty® 350
Millermatic® 252
Syncrowave 351
SuitCase® X-TREME™ 12VS
Millermatic® 211 Auto-Set™ w/MVP™
Spoolmate™ 100 Series
Diversion™ 180
Spectrum® 625 X-TREME™
09-28-2012, 06:34 PM #35
Drive roll tension was too tight for me. Dropping the temp down to 1 didn't help at all. Still around 4 to 5 on the temp and 85ish on the wire speed seems to work good for me. About a 1 inch stick-out and I'm good to go.
Miller Dynasty® 350
Millermatic® 252
Syncrowave 351
Diversion™ 180
09-29-2012, 05:13 PM #36
- Sep 2012
- 9
10-02-2012, 09:20 PM #37
- Sep 2012
- 8
eighttrayjourneyman
What size is your parent metal ? For 3/16s in my case, that heat setting your using is way too cold. You must be down to a guage size to run that cold. If you use the settings I mentioned you have to experiment with distance to keep from frying tips, your still too close for that heat. At your heat range dont believe it will spray arc, hope you have a handle on it keep puddling Aluminum is best welded using a spray arc
10-08-2012, 08:49 AM #38
10-09-2012, 09:47 AM #39
Member
- Nov 2011
- 36
Miller 211 & series 100 Spool gun what a POS!
Any resolution to OP's problem/issue?
10-09-2012, 12:03 PM #40
- Apr 2011
- 315
