Results 11 to 17 of 17
    Oct 2008
    taxachussetts
    416
    I run my 211 endlessly. I've never seen a machine so perfect with the presets. if your burning though 3/16 then I would say you have something set wrong for the wire your using.
    TB 325
    TB 302
    dynasty 200sd
    spoolmatic 30a/wc24
    suitcase x-treme 12vs
    miller 211
    evolution rage 2
    Oct 2009
    Reno, NV
    299
    I really like my 211 and use it a lot. I will say, though, that I just "kind of" use the settings around the knobs to get in the ballpark for whatever I am welding, so I haven't really noticed that it welds "too hot" or "too cold" or whatever. I usually just sort of take a stab at where the knobs should be, make a little test weld and then crank it in whatever direction I think it needs to go....or maybe just move faster or slower. Good welds are, after all, NOT about the automation, but are all about using your judgement to see how the puddle looks and moves and then look at the finished weld. Make adjustments from there. Granted, the numbers on the machine should get you "in the ballpark", but they can not and WILL NOT always be exactly right for every situation.
    I am NOT saying that I am some kind of a magical weldor, but the difference between being a WELDOR and just a part of some big machine that calls himself a "Weldor" is using judgement and experience to figure out problems yourself, set your machine correctly yourself and NOT just do what someone or some chart tells you to do.
    Don J
    Reno, NV
    Jun 2009
    greenfield new hampshire
    884
    are the door charts for co2 or 75/25, what are you using for gas, co2 will run way hot
    4,457
    Too hot is just right. The door charts are always too cold for me, just right for V up but I usually have these little machines set to wide open.
    Nov 2011
    159
    Then you are welding material that is too thick for its capabilities; must have a great duty cycle set like that
    Of all the different Millers we've owned over the years the door charts have always been a little on the high side, always thought it may be a liability issue. A good weldor doesn't need charts or digital meters to dial in a machine.
    Miller Trailblazer's ( 2 )...MillerBobcat 250...Millermatic 251's ( 2 )...Miller Syncrowave 200...Miller Syncrowave 180SD...Miller 12VS Suitcases ( 2 )... Hobart Hefty CC/CV Suitcases ( 2 )...Miller 30A Spool Guns ( 2 )...Miller WC 15A Control boxes ( 2 )...Thermo Dynamics Cutmaster 50 Plasma Cutters ( 2 )...Thermo Arc Hi Freq Units ( 2 )...Smith / Victor O/A Sets...DeWalt Power Tools...Craftsman / Snap On Hand Tools... Two Dodge Mobile Rigs
    Jan 2014
    Northern West Virginia
    37
    Default Really?
    I would think that a 'good welder" would be the first man (or woman) to look at the charts when first dealing with an unfamiliar machine. Those of us who are not clairvoyant tend to use them for at least initial settings, and then fine-tune from there.
    From a marketing standpoint its probably a good idea to have them burn a bit on the hot side. No new owner will ever be displeased to discover that their shiny new blue is more powerful than they expected and when they reach over and turn that dial down it does a lot more to assure themselves that they chose wisely than if they have to turn it up to get the job done.
